what is the benefit of switching out the head units???
I'm mid way through modifying the console right now. It is really simple. It takes quite a few cutting discs with the dremel but its going well so far. If it all works out ok I would be willing to modify these if anyone wants one.Props for getting in there and making it the way you want it.
Do mine next.
No XM built in. Need a module to get it. I dont like sat radio to be honest. I had it for 3 years and listened to it maybe 10 times. I did get the HD radio module and of course the ipod cable. I'll get into those a bit down the line when i get some serious distance into my build.No, I agree. Props on your setup. No XM with that unit, right??
The tweets will be fitted better when i get some free time. I have several things to do to the caddy before i can get back to finishing details on this audio project. The tweets will be fit a touch better and blended into the pillars. I really need to find a paint that will match the stock paint. The console will be better fit as well:2thumbs: great thread, way to be original using the cts DIC. real clean set up too. only thing i don't like is the front tweeters, they look tacked on.. i guess im just a fan of the stock diamond shaped shrouds.. but i dont know anything about audio.. i dont really think the stock system is that bad.:duck:. just a little weak.. in the bass and volume department.. i can listen to it full blast when the windows are down..
To answer the first question yes, the knobs are needed. I did mention that i cut a bit low on one side and therefore kind of screwed the right knob up. I will have to fix this issue later on to adjust the clock as it shows the wrong time. I can scroll between all the stuff still but i want to adjust the user settings and time so i do need the knobs. I did fill most of the lines and un needed stuff on the pieces though.Excellent install and writeup richdash. Are the two side knobs still needed for DIC functionality or could they be removed/filled in?
Any issues with rattles/buzzing in the door or overall? I'm trying to track down a buzz in my install during certain notes and it sounds like its coming from the front door lock hardware.
I hope I'm not sounding too much like a noob here, but can someone direct me to this FAQ that is mentioned? Seems to be an integral part of his installation research.For the disassembly I will follow the write up that was done in the FAQ. Without reading that for hours on end I would not have attempted this.
