1 - 20 of 284 Posts
OK, I'm willing to do the dyno runs at FAST Specialties. They've agreed to discount me some dyno time on a slow day. I'll put my stock air intake back in to baseline. I'll do multiple runs for each modification and post the dyno sheets. That way the tests will all be on the same car, on the same dyno, on the same day, on the same fuel. I'm not, however going to cut up my stock airbox or buy a K&N kit. So if you True Believers out there want a real comparative test someone needs to send me the parts. I'll pay the freight on any part back to the owner.
Any takers? Time to put up or......
I'll volunteer my K&N, since I think I'm one of the last few guys who still haven't gone to the Volant or TonyA yet. When is your dyno day? I can probably take it off tomorrow.
2014 Cadillac CTS VSport
Now this is what I like when someone steps up to the plate to end all the BS.
Cool, thanks Krank, I just pm'd you my address.
I'm traveling for 8 out of the next 10 days. SO the test will probably be the week of the 24th.
CTS
I'm willing to help defry some of the cost, how much will the dyno runs cost? If I contribute say $20 via paypal will that help?
Devil_concours said:
how long does the pcm take to relearn?
I was wondering about that myself, even though in past threads, it has been said to be an "almost instant learning curve"; I believe those were Robert's words, correct me if I'm wrong. I know with my car after I put my K&N on, I had to run it through all the gears at WOT to actually get it to set into a certain shift point, which would mean that HaveBlue would need to drive his car around a bit before putting it on the dyno. Anybody with the Volants notice anything like this?
Black the Darkside
My input and it may be moot. Part of the TonyA design incorporates an attempt for ram-air at the front bumper. If the car is at a static position this will not be reflected on the dyno. Like I said, it could be a moot point if the ram-air doesn't increase the HP. We know it did for the ram-air '68 442 Oldsmobile. HaveBlue the TonyA will require you to cut a 3" hole in your airchamber flap!:disappoin
But I must say this is a cool test using the same engine on the same dyno on the same day! Can't wait for the results.
1968 Ram-Air Oldsmobile.
[font=Arial, Verdana, Helvetica, sans-serif]Special 5-inch diameter hoses pick-up cool fresh air via scoops mounted between the quad head lamps (over and under the parking lamps) for the Quadrajet 4-barrel. Option was listed as dealer-installed
[/font]
The TonyA might be hard to come by because, afterall, it is done with owners' stock airbox so it's not something easily temporarily replaced. I'm not too worried about the ram-air problem, just make sure the fans they hook up in front of the car are big, and have them point one head-on to the front bumper instead of downward onto the engine block.
Black the Darkside
Some of the guys bought a second airbox to modify. Maybe one of those mightbe kind enough to supply?
How about shipping cost both ways. Who pays?:confused:
Regarding Ram-Air, did you notice in that pic that Olds used TWO 5" air hoses up to a single 4 barrel carb? That's bigger than our whole air chamber. Of course the were feeding +400HP engines too:D
HaveBlue, great minds think alike. I just bought a used Volant this week from Doug (forum member), and I contacted AED Performance in Richmond (about an hour away) yesterday. They have a publicly available Mustang Chassis Dyno. I want to do a few runs with the TonyA, plug the hole and replace with factory filter for a second run to replicate the factory airbox, then install the Volant for a third run. As am engineer, I'm also tired of all of the spectulation and want to really know what difference it all makes. Although we can't replicate the 'ram air' effect of sucking air from the front, it will at least be less restricted cold air. My gut feel is that the TonyA and Volant will be neck and neck, but no more than 5 RWHP above the stock airbox.
I'll also pick the best of the airboxes, based on the runs, and re-run in a few weeks, after installing the Borla dual exhaust (also thanks to Doug). My runs will be on a 3.2L, so we should have some great datapoints. I may be required to do another run, after Pete releases his ESC. :lildevil:
2016 ATS-V | 2012 CTS-V
I had a typed up a post yesterday about the PCM re-learning as a factor, but I ended up not posting since I didn't want to add confusion to the waters. It is a factor. You should probably reset the PCM before every run. The re-learn takes a while.
You might see a situation where you dyno stock, add CAI, dyno again and find you picked up 20hp or something. Once the PCM gets used to more air it might re-learn with more air and end up at something more like 10hp. A PCM reset would eliminate this, but using a resetted PCM isn't quite fair either...
Banned
odysseus said:
Although we can't replicate the 'ram air' effect of sucking air from the front, it will at least be less restricted cold air. :lildevil:
I dont think it will be an accurate test because you cant repruduce ram air! I had this same problem running my R6 & R1 on a Dyno...............
Discussion Starter #18
[/font]
I don't belive the "ram effect" will be a factor. The only way this really works is a direct shot to the intake manifold (like the SLP Firehawk hood on the Firebird). In this case it only acts to quickly fill the airbox with fresh air. The air has to turn 90° through the filter and MAF and 90° into the throttle body.
Regard shipping costs, I've agreed to pay return shipping already.
CTS
The other thing is that on a dyno they do use High speed fans to cool the car since its a static sest, so I though the ram air would at least get some flowing air hitting it???
1 - 20 of 284 Posts
