Hi all!, So I am having this problem for the second time in just a two years on my 2008 CTS with remote keyless entry. The front driver side door will not actuate. In order to open the door I have to insert the key. Needless to say this is beyond frustrating and people are starting to wonder why my door handle of all things never seems to work. Passenger side works fine and the back doors unlock and lock remotely with no problem. There was no intermittent issues with this, it simply worked fine one day and then stopped working overnight with no warning.
Before I look into having the actuator replaced (again) or the microswitches, I am wondering if it could be a bad relay or some other simple fix. I looked at the fuse box maps and can only see a "Passenger door module" relay in the trunk fuse box. Does anyone happen to know which relay would be the culprit here? Or if there are any other easy fixes I can try before I start pulling door panels or throwing parts at it? Any advice would be very much appreciated!
Also Just a note to Cadillac Canada here: I payed Mcnaught Cadillac Buick GMC in Winnipeg over $300 to have this exact same issue repaired on the same door barely 2 years ago which was of course not covered by the extended warranty I was sold. I understand this is an older vehicle but it barely has 115,000km on it (71k miles!) and the components were replaced barely 2 years ago. I hate to say this, because I love Cadillacs *(this is my second) but i'm not sure i will ever feel comfortable buying another one with these kinds of parts quality issues on a system that should not fail every two years. You would think Cadillac Canada wouldn't wish to forfeit the customer lifetime value of a loyal customer over a door handle! But I digress.
Thanks again CF.
Thanks again CF.
