Yeah, but did you have a quick disconnect steering wheel?
Yeah, but did you have a quick disconnect steering wheel?I used to run Delrin bushings in my SHO...
No clue yet. Way too customizable and too many optionsWhat size Hyperco springs? I've got a few left over that fit the GC kit...
Yep, thats my other choice.Chris,
Did you look at the Katech LS9-X(orR) clutch? It uses OEM disks, with a Katech lightened flywheel. I've had *ZERO* issues with mine. It might be nice to put a part on your car that you know you won't have any issues with, since you are changing so much other stuff all at once.
-Chris
I think so, they had a vette upper shaft just in case. He said it went on with minimal modifications. I'll double check for you.What Steering wheel hub did you go with? Does the common GM adapter have the same spline?
Thanks,
John
Not too long. He just needs to figure out pricing. They won the Grand Am race last weekend and he was busy...When will those bushings be available?
I NEED EM!
-Chris
We ended up using a C5 Vette upper steering shaft and a corvette hub...What Steering wheel hub did you go with? Does the common GM adapter have the same spline?
Thanks,
John
