41 - 60 of 209 Posts
2005 CTS-V Racecar, 2018 Escalade ESV, 2019 CT6-V, 2023 Escalade-V ESV (incoming)
Discussion Starter · #42 ·
Do you have a handle on how much weight the cage is adding ?
Not exact numbers but with the removal of the stock seats and all interior trim they figured it to be pretty close to even.
With the addition of the lexan though we're pretty confident we are well under now.
Discussion Starter · #43 ·
*UPDATE* 2/24/2012
The cage is all complete and welded up. Car is in the paint shop being prepped for paint...
Vehicle Car Auto part Rim Automotive exterior
Land vehicle Vehicle Car Auto part Automotive exterior
Vehicle Car Auto part Hood Automotive window part
Vehicle Auto part Engine Automotive exterior Car
Reactions: yooper
05 CTS V 07 ESCALADE
Looking awesome Chris. You're on your way man!
Discussion Starter · #46 ·
You're missing a rear strut tower brace there :). Could it be integrated into the roll hoop ? Would that even make sense ?
Its actually integrated into the cage, you can kind of see it in the 4th picture.
The pictures were taken by the shop at certain angles on purpose, to not give away too much info...
Plus my original brace will still bolt in on top if needed.
Escalade ESV and Caddy powered Chevy
Looks good, another great project! Will the rules allow you to run that pad in picture #4 up and over the top of the shock mount, fill in with a continuos gusset and count as one attaching point?:thumbsup::thumbsup:
Discussion Starter · #49 ·
* UPDATE * 3/5/2012
Interior and cage just painted.
Coming out of the booth to get unmasked and re-assembly to begin this week...
Glass Vehicle Room Architecture Window
Automotive exterior Tire Automotive tire Wheel Auto part
Vehicle Automotive exterior Tire Wheel Automotive tire
Wheel Spoke Bicycle wheel Rim Automotive wheel system
05 CTS-V
....:highfive:
I wish I could do that to mine but shes going to be my DD for a few lol. Great work! I converted my interior from tan to black but still need rear seat belts, the pannel below the back window, the front pillars, side, and sail panels, as well as headliner and sunroof controll deal if you want to sell that stuff....
Discussion Starter · #52 ·
*UPDATE* 3/29/2012
Reassembly coming along nicely.
Wiring is being put in place and the dash is back in. Provisions for the lexan windows are done.
The Momo steering wheel arrived as well as other misc parts.
Trans Cooler, Rear Diff Cooler and Oil Cooler being routed. Headers and test pipes (thanks to yooper) arrived and are installed. Fire system and control arms are going in as well. Just contemplating doing the clutch, etc while its still apart.
Sorry no pics yet...
*UPDATE* 3/29/2012
What kind of provisions are necessary for the lexan windows? Tabs on the exterior?
Are the pieces of lexan flat sheets or preformed?
Discussion Starter · #58 ·
They look to be threaded inserts that drop into holes that were drilled around the perimeter where the glass would normally sit.
The lexan came slightly pre-formed to an extent but all pieces were precut and lined up quite well according to the guys at the shop.
Material property Textile Paper Auto part Plant
Textile Linens
Discussion Starter · #59 ·
Please please please weigh the car at different stages so that we know how light we can get a V.
They've got the numbers from when it started off, but unfortunately I've been tied up at work for the past 3 months so I'll only have beginning and end weights...
*UPDATE* 4/6/2012
The suspension is apart and the needed measurements have been taken. Waiting for Delrin material to machine into bushings...
Momo wheel mounted up with very little modification, just waiting on the QD
