1 - 20 of 209 Posts
2005 CTS-V Racecar, 2018 Escalade ESV, 2019 CT6-V, 2023 Escalade-V ESV (incoming)
As some of you guys know, I've been bouncing around the idea of converting the V into a dedicated track car.
Main use will be to run NASA's ST2 class with the possibility of running in other SCCA classes as well.
Today, I'm happy to report that the first step in the build process has begun.
I hope to provide a step by step process that will detail all of the changes from start to finish...
Vehicle as it stands today road ready is:
2005 CTS-V
Light Platinum w/ Black interior
LS6/6 speed tremec
11,771 miles
Current Mods:
Magnaflow Cat-Back exhaust
Diablo Predator tune
Ron Davis Racing radiator
FG2 Shocks
UUC Poly motor mounts, tranny mount, and diff bushing
UUC short shifter
Spectre Werkes delrin cradle bushings
Rear Strut tower brace
UUC Braided brake lines
GM Performance/Brembo cross drilled rotors
Motul 600 fluid
Michelin Pilot SuperSport Tires
12/4/11: Conversion
All Fab work for the rollcage as well as complete gut of the interior and removal of all non-necessary parts is being done by Phoenix Performance*
Last year at the V Performance Lab @ MMC, I met John Heinricy who recommended I get in touch with the owner, Joe Aquilante, who happens to build and maintain some of the Vettes that HeinRocket has had much success with running in the SCCA ranks. It also didn't hurt that Phoenix had built the V that John Buttermore has had his success in T2 so I know they have experience working with V's
First order of business is to completely remove the interior and begin fabrication on the SCCA/NASA legal rollcage, as well as remove all of the non-essential parts such as the air conditioning and other heavyweight items.
(BTW, please contact me if you should need any stock interior parts)
Pictures to follow soon...
*About Phoenix Performance: Phoenix Performance, LLC owned by Joe Aquilante, is based in a 32,000 sq ft race shop in Phoenixville, PA. Since 1999, Phoenix Performance-prepared cars have won 21 SCCA National Championship Runoffs in Touring and Showroom Stock classes, 2 professional series Driver and Manufacturer Championships, and the GM Motorsports Winner's Circle Award
05 CTS V 07 ESCALADE
Go for it Chris. :thumbsup:
2005 Raven Black CTS-V
got any non peeling radio buttons?
Reactions: VisBoss550
Discussion Starter · #11 ·
Are they going to be using a jig for the fabrication of the full cage - i.e., is it going to be something they can reproduce for other Vs or is it going to be just a custom job?
Pretty certain IIRC they still had the prints for the cage since they built quite a few back in the day. Of course they were also able to add/subtract custom options I wanted
Absolutely Fantastic! Will you be using the offset front upper control arms?:bouncy:
Joe mentioned that they documented the ones they sold recently and his fab guy is able to replicate them if I wanted them
Escalade ESV and Caddy powered Chevy
Interested. Can you elaborate?
GM Racing modified the front upper control arms by moving Two bolts (pivot pts) 5 or 6mm closer to the chasis producing at least 2.5 negative camber. When combined with thier custom sway bars, FG2 shocks, and R compound tires the fun meter starts to rise on the road course.
Discussion Starter · #14 ·
Do you have a race weight in mind? dry or full of liquids
Nothing set in stone as of yet other than to try and shave off as much as I can in increments.
2 piece rotors, TD wheels, carbon fiber race seats, carbon Fiber body panels, Lexan windows, etc.
What I do have is a ratio. That ratio is equal to or greater than 8.70:1.
NASA uses this "adjusted" weight to horsepower ratio to classify the vehicle. Which basically opens up the door to unlimited performance/body/chassis and aero modifications. Certain items such as a dog ring gear box carry a penalty of -0.2 and other things such as it being a four door allow +0.4.
I can go greater than that ratio (less competitive), but under that ratio bumps me into a faster class (in this case it would be ST1 with a ratio of 5.50:1)
My plan is to trim as much as I can and get as close as possible to that 8.70 ratio.
Discussion Starter · #16 ·
im sure you've seen the thread but theres another nasa build on here that talks about his + and - points for his mods, ill see if i can dig it up.
Cant wait to see some more progress.
Yep similar idea, that was for Time Trial IIRC, + or - points.
These get added or subtracted from the overall ratio
Discussion Starter · #18 ·
are you parting with the panels between the rear windshield and rear windows? would love to replace my "broken ones" thanx
Sorry about that Donny. I got your PM the other day but I was just waiting back for an email. I'm pretty certain you are talking about the "sail panels" and unfortunately both of mine have the same plastic tab thats snapped that allows them to pop out erery so often.
You can get in touch with Luke from Lindsay, I think he had them in stock and they were not too expensive IIRC.
Oh yeah, I remember seeing those. Thanks, yooper, for jogging my memory. I was imagining a totally new setup with tube frame type fabrication.
Discussion Starter · #20 ·
*UPDATE* 12/15/2011
Moved into the Roll Cage shop
Removed all of the interior, the windshield and the back glass and everything else inside that would be in the way of the roll cage assembly.
Today, they will start prepping the mounting points for the roll cage and bending bars !!!
Vehicle Car Automotive exterior Engine Auto part
Vehicle Car Auto part Hood Automotive lighting
Vehicle Motor vehicle Car Vehicle door Auto part
Vehicle Car Automotive exterior Auto part Trunk
Vehicle Car Vehicle door Auto part Rim
Vehicle Car Auto part Engine City car
Vehicle Car Engine Auto part Hood
Vehicle Car Vehicle door Auto part City car
1 - 20 of 209 Posts
