I swear I miss out on a ton of posts because of that damn "view new posts" button. I only surf by using that, but if I do happen to look into the individual areas, theres a TON of stuff I miss!!!!
/rant
Sorry 'bout that! Had to vent!
Sal, the biggest restrictions for the stock motor are the intake and exhaust. You can easily open up about 15-20 horses if you "fix" both those poblems.
If you delete home plate and first base (look at your engine and you'll see what I mean) and swiss cheese or cut out the stock airbox, it'll help A LOT! A plain old hockey puck will take car of home plate. I used two 45* 3" pvc bends and a 2" piece of pvc and a 3" rubber coupler (Home Depot, less than 10 bucks) to eliminate "1st base" by making a short "S" shaped path. And the airbox, just cut out the bottom side and front and you'll realy wake the car up. The stock mufflers are very restrictive too. I use Summit Turbo mufflers ($14.75 each!) to replace the stockers. The sound great and an exhaust shop should be able to install them for less than 50 bucks. And they don't intrude, noise wise. But you'll get PLENTY of compliments on the sound.
Also, the throttle body coolant bypass helps out too, and it's a free mod. There's a coolant line that runs from the coolant tank to the TB that circulates hot coolant through it to prevent icing in the winter. It doesn't get cold enough to worry about that where I am, nevermind where you are. So all it does is heat up the air charge into the plenum. Cooler air is "more powerful" air so any way you can cool it will help. So you disconnect that line from the TB side and route it to the intake where the outlet from the TB goes. It's a free mod.
I have pics if you need them.
So if you do those, you're out less than 100 bucks and you'll have a big SOTP improvement. You'll probably be a few tenths quicker at the track too...
