1986 coupe deville
big thanks for all comments and tips from you on my tempermental running deville, it had been run out of fuel just before i got it .......... i didn't know there was a bleed valve on the fuel line :eek:, runs 100 x better now still cuts out occasionally though
thanks again paul
1994 cadillac deville
would a 94 deville with a 4.9 have this bleed valve in the fuel line? is it the valve on the fuel rail?
The valve on the rail is the service port - bleed, pressure checks, etc. The valve on the line connected to the throttlebody vacuum side is the canister purge/fuel tank pressure test port which usually has a green screw cap.
1986 coupe deville
ok so its sill playing up :banghead: every time i stop or back off the throttle it cuts out, into neutral and fires straight back up ....... idles ok in neutral even after been revved .... any ideas getting really frustrated with it :bomb:
You may have to restate your problem, we probably all forgot. the basics are check fuel pressure, clean EGR tubes and since you are having idle problems, might as well do the idle relearn stated in the owners manual.
