1 - 20 of 392 Posts
Cadillac CTS-V
Okay four broken diff's later and no factory warranty on number 3 or 4, I have to find a fix. I broke my last diff about two weeks ago along with the drive shaft and both axles (half shafts)........who wants to know what the parts bill was? I have been running the KARS III kit and it has helped minimize the hop but not eliminate it all together, Well I bought a new carrier and put the KARS kit on minus the carrier bracket (due to the instant whine) put UUC diff bushing in and I believe I cured the hop all together but not with the KARS kit or the bushing. I had custom half shafts made which was GM's fix for the 2009. I'm not sure anyone has figured this out yet. Used was a larger diameter shaft on the left side. These axles use bigger stronger 108mm cv with chromoly cage and race set. The axles are designed to twist at different rates thus reducing the stress on the rear diff and completely eliminating wheel hop. I will put this new product to the test and keep everyone updated. The half shafts are a direct bolt in and swap right in with no other mods. The same design is used by Underground Racing on there world record setting Viper and will support over 1000hp. Kit will run $1800 which is about $200 more than replacing the factory axles from Cadillac, and if we can get together a group buy of 5 sets or more I'm sure we will get a significant discount.
'05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
Re: Wheelhop Eliminated!!!
Do you have to change both halfshafts, or can you just use one bigger halfshaft?
2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
Isn't that what Cadillac did in 06 to fix the problem? All the broken diffs were 04-05 Vs. The 06-07 Vs are not breaking because of the changes made to the diff and the shafts. The reason the 06-07 diffs are breaking in the 04-05 Vs is due to the weak half shafts.
Or so I have been lead to believe.
2015 BMUU 335i MSport, 2006 STS-V--2005 CTS-V ( traded in)
06 and 07 Cadillac used larger half shafts, but not different sizes, as they discovered was the fix with the 09.
See you in the funny papers
04 CTS-V, 05 STS, 07 SRX- All sold :(
Slightly misleading thread title much? I hope your idea works, and kudos for trying it, but it's a little premature to call it "eliminated!" before you've even tested it.
Premium Member
2005 CTS-V
No kidding. It first has to tested to see it actually stops the wheel hop. It also has to be tested to see if stopping the wheel hop simply transfers the energy to the case causing to grenade like the pre-2006 models did. Finally, it seems unlikely it will fix the problem with the differentials becoming noisey overtime which occurs in the total absence of wheel hop.
Cadillac CTS-V
Discussion Starter #8
Sorry to jump the gun but I am pretty much convinced this is it. My V makes over 600 at the wheels, I have never driven my car in the rain even with the KARS III kit on where there was no hop, hence the first time I drove the car home from the shop it was down pouring with absolutely no wheel hop. However I haven't dumped the clutch yet (I'm just a bit scared) I have hammered the throttle at a slow roll and absolutely no hop what so ever. I will become more confidant as my bank account recovers from this last diff replacement and keep everyone posted. It will only be a matter of time before I take her back down the 1/4 mile.
No problem. I'm going to correct your thread title until a test is done then.
'06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
This fix has been discussed before but no one actually wen through with it until now. Kudos to you!
:food-snacking:
2011 Black Diamond CTS-V
be sure to post a video of a roll and a clutch dump once you are confident in doing so
2004 CTS-V
I am subscribing to this thread!
2016 ATS Premium 6-spd MT
Yeah, we've talked about putting a bigger halfshaft on one side and an even bigger one in the other side to see if this would work. Doing just one side is certainly preferable.
And I second RangerRob's request for a video. You'd have several sold in a minute with a vid!
'05 CTS-V
Like half the forum :lol:
Cadillac CTS-V
Discussion Starter #18
Did quite a bit of fairly hard driving today, no hop what so ever. The diff is still brand new, so I'm taking it easy for a little while then I'll get my balls back and go to the track and leave like I'm in a pro mod. All on video of course.
Maggie'd 05 CTS-V
You obviously didnt get your previous axles from Luke.... Going from memory here but I know his price for both was less then the dealer here (Canada) wanted for 1 axle.... memory says about $900us for both. BUT, with proof $1800 might be worth it.
Cadillac CTS-V
Discussion Starter #20
I put a little bit of punishment on the car today, just driving the car the way it wants to be driven..........Still not one bit of hop, these may just be the fix. I will take some vids soon.
1 - 20 of 392 Posts
