1 - 8 of 8 Posts
I have a 1999 Catera and when I started my car this afternoon, the temperature display area above the stereo did not turn on. I can't turn on my heat/ac or see the temp outside. In addition, the automatic feature for the headlights won't turn on either. Could a fuse be blown? If so, does anyone know which one it could be. I'm freaking out because I live in Michigan and its freezing out...I have to get the heat fixed as soon as possible. Any ideas or similar problems? :crying2:
I have the same problem once in a while but it comes back on its own,i have checked all the fuses too,disconnecting the battery for a while might help but you will have to reprogram the roof and the windows,i am still unable to find the problem if you do let me know.
oh oh i know this problem
along with all the other aligning problems i had with my cat. This was one of them.
The fix is free
Though requires the A/C panel to come out.
It turns out that cadillac has a little plug inside of the A/C panel that becomes lose with time. Mine came lose and had no A/C Function and the auto lights didn't work either. I took the a/c panel out and disassembled it and found the loose plug (located on the passenger side). Reconnected it and it worked like a champ :)
OK,
I just lost my display yesterday although the lights still work.
Which fuse was loose ??
What plug inside the AC panel was loose ??
Got any pictures ????
I'll be pulling my AC panel tomorrow, hope it is just loose wiring.
BTW, I have a 97 Cat.
1 - 8 of 8 Posts
