1 - 20 of 23 Posts
1989 Cadillac Brougham D'elegance
Hi all,
Does anyone know if a telescopic steering wheel from a 1980-1984 Deville would fit on a 1989 Brougham? I would really like to replace my Brougham leather wheel for the Telescopic wood grain one on the Deville. Any help would be greatly appreciated. Thanks.
Ram
87 Brougham, 1969 Calais, 95 FWB, 07 SRX, 07 ESV
i think it should fit...if not you could get one from an 87 brougham. mine has tilt and telescope and woodgrain.
1986 Fleetwood Brougham d'Elegance
I'm not sure if you could change it to telescopic without changing the whole steering column, anyone know how the telescopic wheel actually works?
2014 ELR
You must match the wheel to the column. If the car has a tele column, you can swap on any tele wheel. I put a leather wheel from a later FWB on my 81. The pics are in my coupe project thread.
How do you know if your car has a telescopic wheel column?
2014 ELR
Top of the wheel, behind the horn pad, there will be a small lever that slides back and forth. Move the lever to unlock, then pull/push the wheel towards/away from you, then slide the lever the other way to lock.
Discussion Starter · #7 ·
Oh, so thats what that lever is for!! Ok Jay you've done it again. Thank you for your assistance!
yeah when I first got my 87 this guy i know was like "oh you have the telescoping wheel!" and I was like "wtf is that?" lol he got in and showed me and I was like :O amazing!
It's a pretty cool feature.
chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
I didn't know what that lever was for either when I first got the car. took me a while to figure it out. I moved it to unlock position (opposite of how it was normally) and drove around to see what would happen. lo and behold, the wheel moved towards me. made it a whole lot easier to drive with the wheel towards me.
1976 Sedan deVille
Just FWIW: Cadillacs never came with just a tilt wheel. It was either solid column, or tilt-tele, no other way.
The tilt mechanism is simplicity itself: imagine two tubes that just slide together. slit the smaller one down the side closest to the end, but not through to the end, about 1 inch. Weld that end shut. Weld a nut atop the other end. Now take a wedge, insert into the slot, place a rod on top of that, and tighten the rod with a screw through the nut. That screw is what the lever (or horn button on really early models) turns.
The column below the tele mechanism is the same, but to swop you will need everything above the tilt knuckle, and it's probably easier to swop whole columns. And columns definitely have eras, '65 - '68; '69 - '76; '77 - airbag.
Cosmo
i think my 95 is a tilt but not telescope...unless I haven't figured out how to telescope it :(
1991 Brougham D'Elegance 5.7L V8
LOL, my 92 had the telescopic steering....I had never had that on a car before. Old Edward was a bit of a junkheap...the first time I flipped the switch to pull the wheel towards me, the entire wheel came off in my hand. Fortunately I had a FSM and it was easy to put back on.
1976 Sedan deVille
Sorry - I don't play with newer Caddys, so I overlooked that they were/are not tilt-tele.
COsmo
95 FWB Blk on Blk. (120K) 98 Deville Concours, 1991 SDV.
My 89 CDV had tele/tilt then my 90 deville had the first yr. for Airbag = not Tele. I also think that the 2000 or so generations came back w/ the Tele option or something again, of course while maintaining the airbag feature. I really do miss the Tele option on my 3 Caddys....
Discussion Starter · #18 ·
Hi guys,
I recently received my wood grain steering wheel, which I will be promptly swapping out for my leather one. Does anyone know how difficult it is to change steering wheels? Can it be done using a wrench set? I'm not changing the entire column, just the wheel. Any pointers would be appreciated.
1 - 20 of 23 Posts
