G
Guest
·Finally got around to converting to a carb setup on my 91 FWB. After installing an 87 L98 350 (Iroc 5.7) in my 91 which came with a 305 Chevy, the car started running like crap. Instead of messing with sensors or having the ecu recalibrated or any of that, I decided to do a carb conversion and hopefully pick up a few ponies while I'm at it.
Ran into a couple of problems but minor. I'm using a Holley contender intake, seems to have a cooling port on the passenger side front of the intake instead of passengers side rear that the stock TBI intake had, is this a prob? And more importantly, is this a cooling port? Could I hook up the cooling lines for the heater core to the water pump itself? It has a blocked off port that I could use.
Also having issues finding a proper throttle/kickdown/cruise bracket but I'll figure that one out. I'm eager to see how she goes with the carb setup. Besides the fresh motor (6k miles), I've installed a true dual exhaust with Magnaflow mufflers, high perf distributor and 3.73 gears. I bet I can outrun an LT1 Fleetwood or at least keep up with one. Cam and roller rockers coming soon! Thanks for any help.
