CREDIT GOES TO MAX POWER AT
dieselplace
JUST POSTING FOR ANYONE ELSE WHO MIGHT END UP WITH THIS PROBLEM
Subject: IPC Lighting Inoperative TBC 2A Fuse Open - keywords cluster dim instrument light panel #PIT4365 - (04/24/2007)
Models: 2003-2006 Cadillac Escalade, Escalade ESV, Escalade EXT
2003-2006 Chevrolet Avalanche, Suburban, Tahoe
2003-2006 GMC, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
2003-2007 Chevrolet SIlverado Classic
2003-2007 GMC Serria Classic
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customer may bring in their vehicle stating that the Instrument Panel Dimming is inoperative. After initial inspection, you may notice the TBC 2A fuse that is located in the left IP fuseblock is blown.
Recommendation/Instructions:
If you experience this concern and can not isolate the source of the concern, inspect the wiring coming out of the IP relay block for a short to ground. Reports from the field have found issues with harness pictured below and the concern can usually be located 8 inches below the IP relay block.
(See Photo Below) The arrow shows where the harness rubs on the IP relay block support bracket near the holding clip. Remove the harness from the clip and inspect carefully. Repair as needed and insulate the edge to prevent a repeat occurrence.
MORE INFO gm-trucks.com - CREDIT GOES TO - "98 Z71 SLT"
Just performed a bulletin search. You can fix the problem yourself at home.
Left instrument panel fuse block. CAREFULLY trace the wiring harness from the bottom of the fuse block to a clip. In those 8 inches of harness, GM states they are finding short-to-grounds, which obviously will pop fuses.
So, you have a wire rubbing a clip, causing a short. Check that harness and fix it.
