Ok, who has it installed with video/pictures? What are the hp/tq gains? I’ve seen the YouTube video already.
LF4 Platform Master Tuner
2018 ATS-V M6
These brand new systems are still in pre-order stage. First production batch is scheduled to ship next month. So the only ones who have tested are our beta cars.
People are running high 9s through the stock catback, it's really not a restriction at this point. There's a few slight crimps in the tubing near the X pipe and chassis brace but other than that it's pretty much a 2.75" diameter mandrel bent X-pipe exhaust with a straight through muffler when the valves are open. Any catback change really comes down to if you want a change in tone and increased volume out the tailpipes, not because the stock catback is restrictive and hurting power.
Catless downpipes by themselves really won't increase power without a tune since with the stock tune the ECM is targeting specific cylinder airmass numbers to meet programmed torque targets. Catless downpipes will increase delta P & T across the turbine wheel and as such can support earlier/faster spooling and more peak power because they're less restrictive than cats, but the gains won't be a set number-- they'll be some percentage of your overall power level. For pump gas tunes making ~480rwhp I've seen people state about a 20rwhp difference between catless and catted downpipes... but maybe Scott can chime in with some actual dyno numbers on cars that he has tuned.
2018 ATS-V M6
As usual, tta1456 is dead on the money with his comments above...
Catless downpipes add measurable power on these cars, as long as you have a solid tune. Ours use hollow chamber resonators, which produce the best sound quality and sweet turbo sounds.
ATS-V OEM cat-back exhaust systems aren't really much of a restriction, so I wouldn't expect more than 5 whp gain with any aftermarket system. For us it's more about improved sound and eliminating the on/off silliness of the active exhaust valves slamming open at 3,500 rpm.
