Did a search but didn't find a write up or anything. Are there directions somewhere, don't think my fans are working and want to get in there to check it out
2011 CTS-V sedan, 69 Mustang Mach I
If you are pulling panels off around the bottom, start with the front panel next to the trans tunnel, it pulls straight out. The front corner by the door is hooked into the side panel, pull that next. The carpet under there is just held on by Velcro. Then the back panel you just pull strait forward stating next to the trans. tunnel again. The side panel with the switches is hooked at the top and the bottom pulls straight out . The back panel of the seat back looks to pull up from the bottom but I’ve never had that off.
