1 - 2 of 2 Posts
Hello, I was wondering if anyone has encountered the following issue?
My right rear tail lights wont turn on when I turn my headlights on. I have replaced the bulbs and no change. Signal and brake lights work, just not the running lights. I have also checked fuses and seem to be fine. Don't know where or what else to do. Any info would be greatly appreciated.
Thanks.
96 STS Seville
I have had the same problem with my right tail lights. Turn signal works intermittantly or not at all. effects brake lights. I replace the socket the brake bulb fits in and it alleviated part of the problem. I think another socket needs to be replaced. Look on the side of the white part of the plastic for brown burn marks, that means there is a bad connection inside the socket,
1 - 2 of 2 Posts
