Hello,
So, I have tail light that's out... What LED can I use to replace it as the car came with LED tail lights when I purchased it... Thanks.
LED taillights are not OEM, I believe there are 3 or 4 different brands out there (with possible different type LEDs used)....and to my knowledge, none of the aftermarket taillights come with user replaceable LEDs (meaning, the assemblies are probably glue together, and the LED's will be directly soldered to the board). But, you still may be able to crack open the light assembly and replace an LED.
Also, I'm not sure anyone will know the LED type, you may need to pull the light, open it, and see what LED type your particular tail light is using. Can you post up more info...like the brand of the taillight?
