Tail light question
1060 Views 5 Replies 4 Participants Last post by  SSTUD
Hello all, i just have a simple question. I was wondering if anyone could provide me with the part# for that tiny light bulb that goes in the rear tail light assembly. Mine burnt out and i have to replace it. Thanks
Tail/brake light bulb? It's a 3157.
ok i will have to check its the small one in the tail. The bulb is about the size of a pea that goes in the rear valance.
The small bulbs in the trunk mounted lamp assembly are #194.
#194 push-in type. Some of the bigger auto stores have them in blue and red also. OK if it's for the tag light. Not OK if for a side marker........Make sure you use some non-hardening sealer around the studs for both the outside light assemblies and the center (trunk) light assembly. Some vehicles have had leaks there.....
Thanks for the help this could be where the water is getting into my trunk. My rear tail light valance is full of water. Everytime it lightly rains i always get water in my trunk :bonkers: So that tail light is probably a dealer item then
