So I just got my 1997 SLS out of the shop to have the front-left hub and bearing replaced, but my traction control light is still on, which leads me to believe that it's a wheel speed sensor problem. Is there anywhere online I can buy them? And is it possible to get them replaced when I get...
Need to replace pair of bushings on my 1984 Eldo where the top of the transmission lever connects to the steering column .... apparently known as "Range Selector Equalizer Lever" they are GM part numbers (1) Bushing 00563565, and (2) Grommet 00563566. Out of production mid 1990's. Find no...
I am rebuilding the steering linkage on my 81 Eldorado. The pitman arm removal was last to be removed. Had to use angle grinder to carefully cut it into 3 pieces to loosen from around spline shaft.
My ? is there a tip to installing the new pitman arm as the cross member is too close to the...
