1 - 1 of 1 Posts
1990 Cadillac deville
I had to replace my TV cable/Detent cable. To do so on the enginge block where you hook the TV cable to the TV link in the trans, I had to lift the cable out enough to unhook it from the TV link coming out of the trans. I was worried about the link falling back into the trans so I had a pair of small needle nose plier's hold the link right at the opening of the whole. No that I have hooked the new cable up, the link does not set back down into the trans and if I try to hook the TV cable end on the throttle body I can not achieve WOT. So I am trying to find out is how to get the TV link that originates in the trans to slide back in the trans so that the cable will function as it should.
1 - 1 of 1 Posts
