Starting a separate thread for the real swap.
I decided to replace the 440-T4 that's in my 85 with another 440-T4 for now, since its the cheapest and fastest fix, and I can take my time working on a 4T60-E build on the side without the car being down. I found an 89 SDV nearby with a trans that had been rebuilt for GM only $250, so went with that. car-part.com (Hollister) says its not interchangeable but I can't find any differences that would matter--TCC code is the same part number, CV shafts are the same part numbers, same gearing and tire size, same exterior wiring connectors and internal switches, etc. 89 should have the improved internals, so hopefully won't have the problems that my 85 has. And it has been rebuilt for GM so probably some other improvements.
The outside housing is filthy and covered in grime from sitting. There is a heavy grime stain on the side cover where tranny fluid seems to have leaked through the gasket (no engine oil sources nearby). The fluid was cherry red like it just came out of the bottle. The input seal behind the torque converter is in very good condition, metal is silver and rubber is black. So just from that it looks like the outside is in bad shape but inside appears to be very good. The donor vehicle has a little over 200k miles on it but the transmission is a reman that could have been installed whenever. I ran the VIN through car-fax but didn't get any hits on trans rebuild. I had it delivered to a trans shop nearby for inspection and rebuild, and he is talking like just clean it up and install as-is. Interesting to hear a trans shop say that--usually their solution to everything is a rebuild. We will see how the inspection goes.
Haven't had a chance to take pics yet sorry!
