2005 CTS 3.6 Sport Lux
Your help is greatly appreciated here, does anyone know if the Eibach CTS-V kit will work in my 2005 CTS and if it does will it lower my car any since the V is much heavier? Thanks for your help.
The rear springs are identical between the kits. The fronts are progressive on the V and is lower (-1.6", I believe). The CTS fronts are linear with 1.2" drop. They will bolt on, but you'd be giving up more suspension travel.
1970 Eldorado.
I have the V-kit I believe, since my front is a little lower than my rear (I did modify the FE4's with spacers).
It works and it's all ok. I didn't even know there was a separate Eibach CTS kit opposed to the V's...
