The proper way to diagnose vehicle height issues. I performed on my vehicle and found it to be just inside tolerance.
Suspension General Diagnosis - DTS SPECIFICATIONS
Trim Height Specifications
DIAGNOSTIC INFORMATION AND PROCEDURES
SYMPTOMS - SUSPENSION GENERAL DIAGNOSIS
1. Determine whether the vehicle is equipped with an electrically assisted or active suspension system.
Drive Type/Model Service Allowed Service Preferred
Z Trim Height
6KD69, FE1 30-50 mm (1.2-2.0 in) 40 mm (1.5 in)
6KE69, FE1 30-50 mm (1.2-2.0 in) 40 mm (1.5 in)
6KF69, FE3 and F45 30-50 mm (1.2-2.0 in) 40 mm (1.5 in)
Fig. 3: Measuring Front Suspension "D" Height Dimension
D Trim Height
6KD69, FE1 76-96 mm (3.0-3.8 in) 86 mm (3.4 in)
6KE69, FE1 76-96 mm (3.0-3.8 in) 86 mm (3.4 in)
6KF69, FE3 and F45 76-96 mm (3.0-3.8 in) 86 mm (3.4 in)
Fig. 4: Locating P And R Dimension Measurement Areas
P Trim Height
6KD69, FE1 721-741 mm (28.8-29.6 in) 731 mm (28.8 in)
6KE69, FE1 721-741 mm (28.8-29.6 in) 731 mm (28.8 in)
6KF69, FE3 and F45 726-746 mm (28.8-29.6 in) 736 mm (28.8 in)
R Trim Height
6KD69, FE1 719-739 mm (28.3-29.1 in) 729 mm (28.7 in)
6KE69, FE1 719-739 mm (28.3-29.1 in) 729 mm (28.7 in)
6KF69, FE3 and F45 724-744mm (28.5-29.63 in) 734 mm (28.9 in)
TRIM HEIGHT INSPECTION
Trim Height Measurements
Trim height is a predetermined measurement relating to vehicle ride height. Incorrect trim heights can cause bottoming out over bumps, damage to the suspension components and symptoms similar to wheel alignment problems. Check the trim heights when diagnosing suspension concerns and before checking the wheel alignment.
Perform the following before measuring the trim heights:
1. Set the tire pressures to the pressure shown on the certification label. Refer to Label - Vehicle
Certification, Tire Place Card, Anti-Theft and Service Parts ID .
2. Check the fuel level. Add additional weight if necessary to simulate a full tank.
3. Ensure the rear compartment is empty except for the spare tire.
4. Ensure the vehicle is on a level surface, such as an alignment rack.
5. Close the doors.
6. Close the hood.
7. All dimensions are measured vertical to the ground. Trim heights should be within 13 mm (0.5 in) to be
considered correct.
Z Height Measurement
The Z height dimension measurement determines the proper ride height for the front end of the vehicle. There is
no adjustment procedure. Repair may require replacement of suspension components.
1. Lift the front bumper of the vehicle up about 38 mm (1.5 in).
2. Gently remove your hands. Let the vehicle settle.
3. Repeat this operation for a total of 3 times.
Fig. 2: Measuring "Z" Height Dimension
4. Measure from the pivot bolt center line down to the lower corner of the lower ball joint in order to obtain the Z height measurement.
5. Push the front bumper of the vehicle down about 38 mm (1.5 in).
6. Gently remove your hands.
7. Allow the vehicle to settle into position.
8. Repeat the jouncing operation 2 more times for a total of 3 times.
9. Measure the Z dimension.
10. The true Z height dimension number is the average of the high and the low measurements. Refer to Trim
Height Specifications.
D Height Measurement
The D height dimension measurement determines the proper rear end ride height. There is no adjustment procedure. Repair may require replacement of suspension components.
1. With the vehicle on a flat surface, lift upward on the rear bumper 38 mm (1.5 in).
3. Repeat the jouncing operation 2 more times for a total of 3 times.
4. Measure from the front outboard control arm bolt center line to the bottom of the control arm wheel
bearing and hub face in order to obtain the D height measurement.
5. Push the rear bumper downward to 38 mm (1.5 in).
7. Repeat the jouncing operation 2 more times for a total of 3 times.
8. Measure the D height dimension.
9. The true D height dimension number is the average of the high and the low measurements. Refer to Trim
10. If these measurements are out of specifications, inspect for the following conditions:
Improper weight distribution
Collision damage
Worn or damaged suspension components
Measuring the P and R Dimension
Use the following procedure to check the P and R dimensions.
1. Use your hands to lift the front bumper approximately 38 mm (1.59 in).
2. Remove your hands and allow the vehicle to lower.
3. Use your hands to jounce the front of the vehicle downward approximately 38 mm (1.59 in).
4. Remove your hands and allow the vehicle to rise.
5. The dimension (P) for the left and right side of the vehicle is measured from the bottom lip of the wheel opening to the ground measured at the center line of the front wheel.
6. Compare the measurement to the specification table. Refer to Trim Height Specifications
7. If the measurement is outside of the specified range, replace the front springs. Refer to STRUT, STRUT COMPONENT AND/OR SPRING REPLACEMENT
8. Use your hands to lift the rear bumper approximately 38 mm (1.59 in).
9. Remove your hands and allow the vehicle to lower.
10. Use your hands to jounce the rear of the vehicle downward approximately 38 mm (1.59 in).
11. The dimension (R) for the left and right side of the vehicle is measured from the bottom lip of the wheel opening to the ground measured at the center line of the rear wheel.
12. Compare the measurement to the specification table. Refer to Trim Height Specifications
13. If the measurement is outside of the specified range, replace the rear springs. Refer to COIL SPRING REPLACEMENT (FE7) or COIL SPRING REPLACEMENT (FE1 AND FE3)
