Try setting up the allocation unit size (cluster size) to 32KB.I have a 256gb. Formatted it to fat32 just now. Still doesn't work.
Thank you. Trying this now.View attachment 623886
I was able to figure out the "SD card is not recognized" issue:
1st: Per manual, It is recommended to use at least 64GB SD card size, V30. However, I cannot get it to work on exFAT format. I had to reformat the SD card to FAT32. This is the format used by other Cadillac models with surround vision recording.
2nd: You will need a 3rd party utility (e.g. Ridgecrop) to be able to format 64GB SD card to FAT32 if you are using Windows OS.
Hope it helps.
No idea. I just ordered a 128gb. Maybe the system doesn't like large SD cards.Still not working. I’m also using a 512gb v30 sd card. Could that be the problem?
[/QUOT
It could be. Mine is exactly 64GB.Still not working. I’m also using a 512gb v30 sd card. Could that be the problem?
Does it record all the time? Only if an event is detected?View attachment 623886
Hope it helps.
Some information here but certain events will start the recorder automatically like the glass breakage sensor or inclination sensor:Does it record all the time? Only if an event is detected?
Thank you so much!! Reformatted to 64GB, FAT32,32k allocation size, and it works fine! I used EaseUS Partition Master (and paid the $50 for the lifetime upgrades...).View attachment 623886
Hope it helps.
You're very welcome!Thank you so much!! Reformatted to 64GB, FAT32,32k allocation size, and it works fine! I used EaseUS Partition Master (and paid the $50 for the lifetime upgrades...).
Does a Cadillac rep peruse this forum? Should probably be communicated to them. I'm going to chat with my dealership and let them know what the solution is, and recommend that they format customer's SD cards.
Thanks again!
I believe so. 128 didn't work for me.FWIW, I tried a 256GB card, formatted to FAT32, and it didn't work....wondering if 64GB is the upper limit.
So do I format to extFat32 or just Fat32? I have a 64gb and i formatted to extFat32 with a 32 kb allocation and it’s not working. Any help would be greatly appreciatedThank you so much!! Reformatted to 64GB, FAT32,32k allocation size, and it works fine! I used EaseUS Partition Master (and paid the $50 for the lifetime upgrades...).
Thanks again!
FAT32 with a 32kb allocation/cluster size.So do I format to extFat32 or just Fat32? I have a 64gb and i formatted to extFat32 with a 32 kb allocation and it’s not working. Any help would be greatly appreciated
What a mess this is! I called my IT in because my computer won’t do the FAT32 just the extFAT32. So we went through the command prompt and had to set partition and volume and then format it. Now my volume was too big and I have to reformat again. And all the programs that are on the internet cost! What a shame Cadillac can’t do any better than this. This really needs to get figured out quickly by then and they should just give us a free SD card like they do with the maps!FAT32 with a 32kb allocation/cluster size.
Ryan
Mine was a small slot that is vertical next to the fuse box.I popped open the cover in the cargo area where the surround vision recorder card slot is supposed to me. The slot did not have a cover, and has to be inserted horizontally, not vertically. Also, the slot appears to be 3X the width as the card. Perhaps the vehicle did not get the option? It is a 2023 and was built around the 3rd week of production.
I did not have a card yet and did not investigate the area, but I wonder if the car even has it.
