-------------------------my new Dorman surge tank was delivered today. It looks like a pretty straightforward replacement job. Anyone have any tips or cautions? Should I replace the OEM spring clamps with regular hose clamps?
I hear that. Just replaced my overflow tank and I wasn't impressed with the fit.1969byrdman said:appreciate the advice, Bass and Ranger. btw, I'm not impressed with the finish work on the new unit where it's seamed together. Lots of ragged plastic, melted pieces, etc. Not nearly as smooth as the piece being replaced.
------------------------------------:yeah:AC Deco
=======================appreciate the advice, Bass and Ranger. btw, I'm not impressed with the finish work on the new unit where it's seamed together. Lots of ragged plastic, melted pieces, etc. Not nearly as smooth as the piece being replaced.
I've handled a few of the Dorman tanks, also have never seen one that was obviously bad looking. I have sold one once that split quickly and we had to replace it, but the guy is still driving around with it to the best of my knowledge. Maybe yours was the last one built on Friday before the plant closed for the weekend!WOW - very disappointing -
that's the first complaint I have heard about the Dorman tanks -
GM 25774005 - $90.59 - with free shipping -
http://www.amazon.com/gp/product/B0013FW8KG/?ie=UTF8&me=ATVPDKIKX0DER
does NOT include cap - additional $12.53 -
Yup. I've personally seen those same mods add triple that!At least dude!
If you didn't put the stickers on the driver's side rear quarter window you cost yourself at least 30 hp.Just installed the new tank. The minor imperfections wouldn't have been visible from the top, but I went ahead and smoothed off the plastic with a Dremel. The whole job took only 20 minutes; would have been less but retrieving one of the nuts I dropped took 5 min. Dexcool/distilled water, fire it up and no more "check coolant level". As long as I was working on it, I went ahead and added a CF Performance chip, a turbo impeller in the intake, 1 bottle of octane booster & 1 of Seafoam in the gas tank, a K&N cold air intake, and filled the washer reservoir with dihydrogen monoxide. I figure my horsepower increase was +/- 0%
If the tank wasn't chromed it'll cost you two tenths right off...Just installed the new tank. The minor imperfections wouldn't have been visible from the top, but I went ahead and smoothed off the plastic with a Dremel. The whole job took only 20 minutes; would have been less but retrieving one of the nuts I dropped took 5 min. Dexcool/distilled water, fire it up and no more "check coolant level". As long as I was working on it, I went ahead and added a CF Performance chip, a turbo impeller in the intake, 1 bottle of octane booster & 1 of Seafoam in the gas tank, a K&N cold air intake, and filled the washer reservoir with dihydrogen monoxide. I figure my horsepower increase was +/- 0%
the only stickers I allow on my car are a Longhorn decal, and the NRA sticker. The NRA logo alone adds at least 1200fps.If you didn't put the stickers on the driver's side rear quarter window you cost yourself at least 30 hp.
