While I was in the middle of doing the crossover gaskets on my 96 deville I came across a good amount of oil in the intake manifold, so I decided to take it off and clean it out. When I got it off I looked down all the runners to make sure I got all the crap off the valves when to my surprise the #4 piston had a nice lil puddle of coolant. I had to move the car so I put things back together and started it up.
I drove around for a while without issue the did a block test. I know at this point I blew a gasket but I had done the block test about 10 times since fall and never got a positive result. This time was no different I got a no exhaust gasses in the cooling system. Oh well doesn't matter now.
I have a million questions to ask of this forum in the next few weeks but I will start with some essentials. Is northstar performance still the studs to go with?
Are the felpro Headgaskets adequate?
My engine runs smooth and gas mileage is good should I be looking at any of the timing guides or tensioners?
I will want to do the oil pan and half seal. What is the correct RTV and do I need new girdle bolts?
It is a 1996 base deville with just over 300,000 miles.
