Have noticed that the back of my sunroof seems to be sagging - when closed it is not all the way flush with the roof. Also occasionally when I start the car the sunroof freaks out and tried to close repeatedly or opens on its own. I had assumed it was an issue with the switch - but now that I have seen the sagging wonder if there is a sensor that is telling it that it needs to finish closing? I can push up on the sunroof from inside and it moves up to full closed but will be down a little after driving. It is not leaking....yet.
Is this a common problem? Any solutions other than dealership service fix?
Thanks.
Thanks for the info - not sure it is an electrical issue though. It is almost like whatever mechanism pushes the back of the sunroof to full up closed position is not doing its hob. It doesn't get all the way up and tends to let it sag over time - Is there a spring or lock mechanism? How low can it sag before it starts leaking?
