1 - 14 of 14 Posts
2010 SRX 2007 DTS
My sunroof leaks. It doesn't come up high enough. I have the screws adjusted to their maximum height.
Are there any other adjustments possible? Otherwise I will enlarge the screw slots so that the adjustment range is greater.
Car Automotive lighting Hood Motor vehicle Automotive design
· Super Moderator
2011 SRX4 3.0 4WD, Luxury
gaskets? drains? what have you tried brother?
2010 SRX 2007 DTS
It leaks by the top side of the driver A pillar after a rain
Every other DTS sunroof picture I can find has the sunroof flush, while mine is sunken, despite the screws holding the sunroof at its highest possible adjustment
· Super Moderator
sounds to me ( non expert) like a sun roof drain issue, i would pop the headliner and a pillar cover and check it out.... headliner will be a PITA... they could be plugged, and you need to snake a long piece of weed Wacker cable down them but only the kind that looks like a X from end on) sand off any sharp edges, and snake it down while twisting gently - use a hose on a light trickle for lube, and try and clean the blockage ( compressed air has been use sometimes- but it can blow apart fittings......may the force be with you....
2014 SRX 3.6 Perf. 2010 DTS 4.6 Lux
Trip may be correct about the drain being stopped up but you are right, the glass should be flush with the roof all around. Your dipping corner indicates that the glass may be slightly off center. There should be a place or places where you can adjust how the glass fits in the carrier. I do not know where or how. I would look at the back edge of the glass panel.
Have you made sure the seals are properly lubricated and seated properly?
I have always contended that if the glass closes properly and the seals are in good working order then a sunroof such as in our DTS should not leak. Once you get the glass to close correctly you may find that the seal is deformed from continuous incorrect pressure. Best wishes.
2011 DTS Premium w/1SD | 1999 Deville Base (RIP @179K Miles)
Open the sunroof and pour some water by the corners, check if the water drains out
I had to use a can of compressed air by the drain in the wheel well to drain mine
· Administrator
The sunroof side rail adjustment screws allow for more adjustment than that shown. Something is incorrect in the OP's car.
Parallel Font Engineering Auto part Drawing
Trigger Font Air gun Parallel Gun barrel
Parallel Gun barrel Font Trigger Diagram
Reactions: Omac
2010 SRX 2007 DTS
Discussion Starter · #9 ·
It opens and closes OK, without obvious interference or resistance. I did have to replace the motor when I got the car because it the stop mechanism wasn't working- it would tilt open, but not slide, it'd just buzz.
I'll pour some water for a drainage check
2008 DTS Platinum
Mine clogged at the very end of the drain tube, behind the front wheelwell liner. Trying to push a weedeater line from above didn't work as it caught halfway, but it did the job easily from below. Not difficult to detach part of the liner.
My glass fits badly all around regardless of position, partly because the sheet metal bulges up in the center of the car while the glass is flat. Since my paint is black, I used two layers of electrician's tape around the opening to get it closer to the gasket on the glass, but I still have a little wind noise when the shade is open.
19 EVS Escalade platinum, 09 DTS, 05 Escalade ESV
Considering my teenage drive is driving it and has been in 2 accidents so far
and it needs a $1500 power steering pump repair as the boot is leaking (my mechanic said the car isn’t worth the repair)
I’m not too worried about a patch job on one of the sun roof drains
1 - 14 of 14 Posts
