1 - 8 of 8 Posts
2014 XTS V-Sport Platinum
Okay, I have been trying to clear a blocked sunroof drain today, but can't seem to get the weedwacker line to push through the blockage. Where does the drain exit at the bottom? I'm thinking I'm going to need to remove the front wheel and the fender liner to find it...is that correct? The front left drain is the one thats clogged.
Thanks, Larry. I tried and it got stuck in there, too. So, I poured a cup of water in the pan...right side drained on the garage floor...left side still has water standing in the pan. Any tips on getting the line through the drain?
· Super Moderator
2010 DTS
Hmm. Where did the right side drain from? The only thing I can think of it to locate it and go in from the bottom. DO NOT use compressed air. You may blow the drain hose off and then have to open up the headliner or A pillar.
Update...okay I pulled the left front wheel and the fender liner. There is a soft rubber nipple of sorts sticking out...almost like a flat tipped version of a baby bottle nipple. I squeezed it open (was stuck with gunk) and the waters came rushing out. Cleaned it up good and getting ready to put the car back together.
eldorado
Find the exit and blow up , less chance of tube coming off..If you cant find it find someone who has one with a sun roof (Friend, used car lot, rental) and carry a small soda bottle of water and pour it down theres and look for exit? Get permission first !
1 - 8 of 8 Posts
