2007 Escalade
I recently decided to add 2 subwoofers to my 2007 escalade. I had one sub and amp that I used in a previous car, so I bought an additional sub to match the other. I tapped into the factory subwoofer connection and used a line level converter. From there i ran RCAs to my amp. My problem is that once everything was installed the level of bass seems to be much quieter than with my old set up(same sub and amp just added another sub). Everything is working properly its just not hitting the way it used to, even with the bass boost turned up on the amp. I even tried hooking up just one of the subs exactly the way I had it set up in my previous car and it was still very quiet. Any ideas? Am I getting a weak signal from splicing into the factory sub wires?
2008 Cadillac Escalade ESV Platinum
Is the amp power coming stright from the battery or is it tapped to the factory amp witing
When the system is play do u hear voice coming from the sub
Also what wires did you splice into
2007 Escalade
I do not hear music coming through the sub only bass. That part seems to be correct. I spliced into the four subwoofer wires under the cupholders and used a hi lo converter
