Hi all.
Recently got a '97 Eldorado with 65k miles and just noticed the following symptoms. Didn't notice this during the test drive, unfortunately.
1. When car is in gear (D,3,2,1,R) with engine running, and the car is stopped with the brakes depressed, it will stutter a bit, like it wants to move forward. Can't tell if it's a misfiring or not (I'm no expert), but there are small "pops" accompanied by slight vibration. When in neutral, the engine runs smoothly. Once I press on the accelerator and the car starts moving, the engine runs smoothly...EXCEPT...
2. Sometimes, while at highway speeds, the stuttering will start up again when I accelerate. Does not happen all the time, nor while cruising at constant speed, nor at lower speeds.
I've pulled the codes and had no current codes. I cleared the history a few days ago and no codes have popped up since. The "service engine soon" light came on shortly after I filled up with gas. I suspect the dealer put regular in it while I used premium. It went off after I tightened the gas cap and cleared the codes.
I've searched the forums for advice and here's what I plan to do this weekend:
1. Replace spark plugs and wires (AcDelco 41950 & 9748J).
2. Clean throttle body.
3. Clean IAC (if that doesn't work, replace)
4. Clean EGR
Any other ideas on things to check? I really like this car and am hoping I can solve this issue myself. Thanks!
4. Clean EGR
