1998 STS
Previous posted with no reply - asked where plug in is for block heater on 1998 STS, does anyone know if this exists & where it cld be found????? Help. Tks.:thepan:
I remember seeing the other post. I myself do not know. I would think this info might be in the regular owner's manual. Do you have one?
I had downloaded a manual at work for my 94 eldy. That was some time ago. Now that I am home, I can't remember where I downloaded it (for free).
I just looked at a manual for a 93 Eldy. I know your STS is much newer, but this may help. This is info from the manual:
In very cold weather, 0 degrees F (-18 C) or colder, the engine block heater can
help. You’ll get easier starting and better fuel econonly during engine
warm-up.
To use the block heater:
1. Turn off the engine.
2. Open the hood and unwrap the electrical cord.
3. Plug it into a normal, grounded 1 10-volt outlet.
That is all it says. Hope it helps a little.
Did this option come with your vehicle?
2000 DEVILLE,2001 STS.
I came across an advertisement on the web that listed an engine block heater as an $18.00 option on the 1998 sls and sts.Where it's located..???
your halfway there anyhow.
As has already been mentioned, it is an optional piece of equipment, and if you have one, there will be a cord with a regular NEMA-type plug (like anything in your house that plugs in). It will be under the hood somewhere. If you don't see it immediately, you don't have a block heater.
