I have a 2014 Lux and the HVAC system is driving me crazy (pun intended).
The manual states:
"AC Mode (Air Conditioning):
Press the AC Mode touch screen
control to turn the automatic air
conditioning on or off. If the fan is
turned off or the outside
temperature falls below freezing, the
air conditioner will not run."
Ok, this is good, however the reverse is also true, if the fan is turned back on say to get MORE HEAT in the vehicle, the AC will TURN BACK ON!
I keep playing this game of adjusting the temperature and then having to manually turn the AC mode OFF!!! If it's 40-50 degrees, I don't want the AC on unless I want to eliminate condensation which we rarely get here in FL when it's cold because I vent outside air which has LOW humidity.
Is there another trick I'm missing or am I just stuck in On/Off hell?
The manual states:
