1 - 13 of 13 Posts
Hi,
Here's something that has stumped me for a long time: My cornering lamps on my 89 deville never light up when I turn on the turn signal. I've replaced the bulbs, checked fuses, still nothing, connections look good.
Read everything in the Haynes, Chilton and official shop manual. According to them could it be I need a replacement turning signal switch located in the steering column?
Any help appreciated.
Thanks in advance.
1993 Sixty Special, 1991 Allante
Coupe deBill said:
Hi,
Thanks in advance.[/QUOT
Hi Coupe deBill or anyone else who had this problem,
Did you ever figure out what was causing your problem? I have just started encountering the same problem. Yesterday I noticed that my turn signals seemed to blink slowly so I got out to look at the exterior lights and noticed the cornering lamps were not working at all. I removed one lamp assembly and checked the bulb which was fine. I changed the turn signal flasher hoping it would cure the cornering lamp problem as well. It did cure the slow blinkers but did nothing for the cornering lamps.
How many of you guys have had this happen and what did it take to fix it?
93 Fleetwood RWD, 99 Deville
I know this may sound stupid. But some of the cars I have seen the cornering lamps only work when the headlamps are on. It is that way on my friends 92 deville, but the opposite on my90 seville. Try that and retest. Let me know, Im curious about it now.
Blaze
1995 Deville Concours
I too am having this problem. I have new lamps in my right turn signal, but it still does the frenetic "Bulb is bad" rapid-flash turn signal indicator. My left sides work just fine, from what I can tell (Technically the front lamp mount got ripped off, so I don't know that it works or not, but the running light that is still attached works...), but my left side doesn't work despite being replaced. And it is only my front right side that doesn't work.
You're having some other problem. The flasher doesn't care if the cornering lights are burnt out or not and doesn't do anything to tell you. If you're sure all the bulbs are good there's probably a bad socket or broken wire somewhere.
Well Good golly. This post is over a year old. LOL
Blaze
Well In my opinion,The date of ANY Post in these forums is irrelevant to those of us driving a 'older' model.
By the way ill make sure to post my fix,when its done as I like those cornering lamps and have ZERO other turn sig issues.Ill change the switch in the column and let yall know
kk
1 - 13 of 13 Posts
