im here again thanks to all that can help me on this one...2001 deville that sometimes wants to overheat a couple of weeks ago i did alot of work to this car new radiator fan motors thermostat and still was running a little hot. clear purge lines and still over heating i changed radiator cap and that seemed like that cured my running hot issue....then a couple days ago its started doing it again running hot and just like before turn on heater and goes back to normal temp and i can drive anywhere with heater on...fans are turning on..no air bubbles in antifreeze res...its holding pressure...i know it started to leak some coolant from intake crossover housing but it was running fine just makeing sure that it has coolant everything was okay....then it stopped leaking from crossover intake i was surprised...i did overfill coolant resorvoir a little oover where it should be could that have something to do with problem any info is gladly appreciated....
