your supercharger cannot 'disengage'...its driven off the crank pulley. You got other issues.
F
F
The car does have a rev limiter, are you shifting manually close to redline?there is a studder when the supercharger kicks in. When coming off the line and fully accelerating the supercharger will engage but then as if it hit some type of rev limiter it studders repeatedly and the supercharger disengages totally. I was hoping anyone knew if this is to do with maybe the D3 ECU Box or cadillacs doing?
*Oddly this only occurs off the line or when the car is rolling slowly between 1st & 2nd.
When my car does this, I know that it is wheel spin with the associated wheel hop...usually ocurrs at the top of 1st gear when it is trying to hook up.it studders repeatedly and the supercharger disengages totally. I was hoping anyone knew if this is to do with maybe the D3 ECU Box or cadillacs doing?
Just another chime in, you'll need to remove any mods to check and see if the car is doing it stock. If it is not, then something is up with the mod(s) on the car. If it is doing it without the mods you'll almost certainly need to take it to the dealership and have them have another look at it anyway in a stock configuration. (that way they can't blame the issue on your added mods)
Last year they had to work on mine to fix a lower crankcase oil leak and ended up fooking something up on the supercharger causing me to bleed boost pressure early resulting in a loss of about 50rwhp. It took me proving the car was different/less to get them to seriously go back in and find/fix what they did. Luckily I had several dyno runs done on the car after it was purchased, so I could prove there was a definite loss of HP vs their butt dynos which told them the car was fine. (my butt dyno told me it wasn't). They did find and fix what they did the first time.
Yeah it was that incident. Thanks to your explanation and pictures they figured out what they did and got it fixed.I remember that. The dealership didn't use the proper J-tools to support the supercharger right?
Just so you know...the supercharger does NOT operate independedent of the the engine. When it stops the engine is stopped, when it spins the engine is spinning, they are connected and it does not KICK IN or DISENGAGE.under hard acceleration the car almost seems to shift multiple times in mid gear. The supercharger winds up then stops and then winds up again. The dealership told me the engine is protected so it is not OVER supercharger????
Any ideas?
Great So I am not crazy! I finally had a tech come in the car with me and agree something is not right. They left me a message today saying they would be checking fluid levels tomorrow so I will keep you posted. God I hope this is what it is.Just so you know...the supercharger does NOT operate independedent of the the engine. When it stops the engine is stopped, when it spins the engine is spinning, they are connected and it does not KICK IN or DISENGAGE.
Now, as for ideas...when I had that happen to me, it was as if it was shifting but was still in one gear(in my case it was 1st or 2nd), it was because the transmission had been serviced and was low on fluid. I had the fluid changed over to Amsoil Universal ATF, and you may or may not know,but, our cars do not have a dipstick to check the fluid level, it has a " fill level plug" in the pan. Turns out it was a little bit short on fluid and under hard acceleration the fuid was moving back in the trans away from the pickupup allowing it to catch air. The car would momentarily not pull,or dis-engage, felt like I may have stepped on the clutch to shift(but no clutch), then the lack of accel(for a few miliseconds) allowed the fluid to resume its position in the pan then would re-engage again...Took me a couple of weeks to figure that out!!! Everybody thought I was crazy(normal, that is)but after checking the fluid with the car on the rack and running, removing the oil level check plug, pumping oil in it untill it starts to run out,... it was 3/4 quart low. That filled it and fixed it.:bouncy:
Since you just bought your car, they may have serviced the transmission and did not fill it completely....Check it out.
