1 - 16 of 16 Posts
'94 Seville STS N*
when my sts is at idle, the noise coming from the engine sounds like a diesel
not so much apparent when the car is moving
a real low ratcheting noise sort of
hard to describe
pretty similar to this youtube video's noise:
there is a lot of movement on the belts that spin on the master cylinder? whatever those are that are on the left side of the block
like, the whole mechanism/pulley/belt assembly is going left right left right
possibly causing it? i dunno, they've had that much movement since i got the car, about 6 months ago. maybe something finally came loose?
One of the bearings is going. Most likely the belt tensioner or the idler.
Best bet would be to replace all those parts while you/they are in there since they aren't that expensive, along with the belt.
'94 Seville STS N*
yeah. got an appointment on friday morning.
good to hear that it isn't going to cost an arm & a leg ranger. :-D
just spent a little bit over $500 about 2 weeks ago.
'94 Seville STS N*
turns out it was the tensioner & pulley (at first)
they replaced
no difference in sound
i told them, they tried again
replaced alternator
a little bit better but i can see the harmonic balancer is shaking left to right
$700 later, i'm depressed
oh well
'94 Seville STS N*
Discussion Starter #8
sigh. 3rd time around. they finally suggest the harmonic balancer. and they're actually trying to charge me for it. PLUS THE TENSIONER AND PULLEY. WHAT THE ****. $650
i said it took 3 tries, and three parts later, to figure out the true problem as to why these bearings keep coming loose? and you're going to continue charging me? when i suggested that as a cause to begin with?
the guy is like yeah well uhh i don't know the situation very well, you'll have to speak to the service manager
i replied with an okay
"the service manager isn't here"
LOL
what the ****
'94 Seville STS N*
Discussion Starter #9 (Edited)
well, after a lot of arguing, i got them to budge.
only paid for parts on the pulley & harmonic balancer. $250 bucks instead of the $600+
noise is gone completely.. what i'm worried about now is, at idle, a bit of vibration and an odd low rumble that accompanies it, like there is a load on the engine
what are the symptoms of the main bearings wearing down? could a wobbly harmonic balancer cause this to happen?
'94 Seville STS N*
Discussion Starter #10
also,
had this fault code in history after getting the car back:
P1110 Atmospheric Pressure Sensor Low Input
could this get set off by the techs ?
'94 Seville STS N*
Discussion Starter #11
man. no one cares about my dang car. :p
is it because i've gone against my caddy?? :-D
for i have used the cadillac name in vain
'94 Seville STS N*
Discussion Starter #13
put seafoam through the throttle body
and a lil into the gas tank
temps went wayyy up at the end of blowing all the smoke out
got up to 228 before they started drop
i'll post the vid when my friend sends it to me
'94 Seville STS N*
Discussion Starter #14
ah, just took it for a drive to the grocery store. nice & smooth. no hesitation. the rough idle has come down a sizeable amount (plz don't jinx me :-o).
Premium Member
Next time you take it in for work bring a handful of hundred dollar bills and a big jar of Vaseline. You'll be surrounded by friendly folks in no time.
1 - 16 of 16 Posts
