1 - 14 of 14 Posts
2005 STS V8 AWD
Hi-
I drive a 2005 STS with 91,700 miles. I have used premium fuel with it the entire lifetime of the car. I have heard, not in a direct question, that premium fuel is not required. Is this true? I drive the car gently on a low-traffic commute, and I don't put much effort on the engine. I use 91 octane, and was wondering if 87 was viable.
Thanks!
2005 STS Northstar RWD
Directly from the owners manual of a 2005. So use of mid grade or regular is acceptable, but will lack some performance.
2006 STS 1SG & 2007 STS 1SE
Use 'Top Tier' gas. If you notice ping or knock try 89 or a different brand. Premium may be overkill; some do not notice a difference.
2006 STS V8 1SF RWD
I notice no difference between 87 or 91
2006 STS V8 1SF RWD
1BadCadSTS said:
I notice a difference under heavy acceleration between 89 and 93. Never put 87 in mine and never will.
I use 89 95% of the time as it is usually the same price as 87...She gets 91 when she gets her Techron.
Was just stating as I have used 87 and noticed no difference.
'10 CTS4 3.6L Wagon prem; '06 STS 3.6L base; '98 Seville STS
i use premium but i still hear a loud knocking every time??
2006 STS V8 1SF RWD
Those 3.6's like to make their presence known...Make sure the oil is always full.
....every time i drive the car, let the engine run...its more of a air puffing (or air being sucked in) sound coming from the right side of the hood, ill make a youtube video of it tomorrow if i get the time
2007 N* STS-4
I was using 89 for a while when the price of gas was mid $4.00 range. When it came down i went back to 93 and it was noticeably smoother and quicker.
08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
Where I live, 91 octane is about $0.10/L more than 87. I fill up about every 10 days with a fill averaging about 55L. So, based on this, I figure the annual difference between using 87 and 91 is about $200.00. Not enough that I care. I do believe, although not necessary, I get better performance.
1 - 14 of 14 Posts
