Hi guys,
I'd need a bit of help here please. 2004 Seville STS 4.6L Northstar. Presently we are in the middle of winter and the car is parked outside, so the car starts its day off 'cold'. After the car has been running for a good while, and she warms up good, all of a sudden it will accelerate on its own. But sometimes it does it, sometimes it doesn't.
Here's what I noticed yesterday:
At idle, it will almost mimic what I do with the accelerator...If I rev to 1500rpm, it will stick at about 1200-1300 rpm. If I rev to 3000rpm, it'll stick around 2700rpm. And so on.
When driving in town, it'll idle and drive around town, I could easily get home without stepping on the gas pedal.
Also, when it does this, it seems to smell of burned rubber.
I removed and cleaned the IAC valve. It had some black soot but it wasn't a disaster either. However, it didn't solve the issue.
No visible check engine codes on the dash. Apart from the issue I mentioned, there is nothing out of sorts with it. (When its not doing the auto-acceleration thing) It will idle normally, rev up and down smoothly, no hesitation or stuttering, no burning or smoking.
Thanks for any help that you can offer.
