1 - 15 of 15 Posts
Cadillac STS 2005
Ok I figure I just list what I have questions about in this one topic :) hope you guys can help me out.
I just bought a silver 205 sts northstar.
The light inside the headlight, not the low/high beam, what is that bulb size?
Also I am thinking about getting a stick or after market touch screen nav screen. what do I gain other the the screen by buying the stock, what do i need to get most of the options? what do i lost if i were to go to a aftermarket head touch screen head unit?
has anyone got 9.5" wide rwd rims under there car that are 22"?
Banned
2006 STS V8, 1999 Seville STS
The search function is your friend for all those questions.
Quickly: you can find the bulb size by searching Headlight in all forums. Note, you have to remove either the bumper or the fenderwells to replace the bulbs.
What do you mean getting a stick?
You cant do an aftermarket touch screen nav. You will lose your driver information center, and its crazy hard complicated to find an install bracket/wiring that works properly. I was going to put aftermarket nav in my CTS, but gave up and just upgraded to an STS with nav in it. You will literally spend a thousand dollars on the install alone on a Nav unit, not including the price of the unit.
Wheels, use search.
2006 STS 1SG & 2007 STS 1SE
Congradulations on your purchase.
Much of what you asked has been discussed in depth. I'd suggest you spend some time with the search feature to get all the info you'd ever want. I'll help a bit, with a few a swings...
I'd check the manual for the bulbs. Did you get one with the car? I've read that while its possible to change the bulbs without removing the bumper, it's not easy at all.
If you don't have factory Navigation, it's not worth trying to add it. The wiring is not there. So if your car doesn't have it and you want Nav, get a Garmin or equivilent.
If you change the Bose head-end, you lose the ability to change your memory settings.
A lot of members go with 20" wheels. 22's would be extreme. Anyone try it?
Cadillac STS 2005
i read people doing 22" but i never hear anyone mention a width. and i see front parking light and turn signal, but what is that little bulb in the headlight called? if i can figure out the name i could find the bulb in the book hehe.
Leave the bumper on, and go through the inner wheel wells. It is much easier that way and less of a pain in the ass...
#2 - YES. You can go 9.5 inch 22 inch wheels and tires. 255-30-22 tires are used on STS's. I would not get the 22es because your sidewall will be a rubber band. You will crack your wheels EXTREMELY easily. I have 245-40-20 inch wheels and tires. I have much more tire and meat for potholes and such.
1 - 15 of 15 Posts
