1 - 8 of 8 Posts
2000 STS in Poland
Gentlemen.
The system of automatic activation of lights took over the lighting of the car - I can not manually turn on the headlights, only the dusk sensor activates them. I searched the forum, but I did not find a specific case similar to mine. What to check first?
Thank you. Jack
Always post code definitions along with the codes. No one has them memorized yet.
2000 STS in Poland
Excuse me. I am already correcting.
DTC B2420 - Dusk Delay Container Failure
DTC B2422 - Interior lamp rheostat failure
Can airflow failure be related to the IPM? Damn ... I don't even know what it looks like, where to look for it ... Or maybe it's not caused ...
If not you - then probably nobody ...
regarding your codes -
B2420 - Twilight Delay Pot Failure -
B2422 - Interior Lamp Rheostat Failure -
these are both within the headlight switch assembly - meaning -
you probably need to replace the headlight switch -
574576
1998 through 2004 Seville use the same part -
there are two different types -
WITH fog lights (the small square button on the upper right corner) -
OR WITHOUT fog lights -
2000 STS in Poland
Please write how to remove the light switch panel. Losing a plastic tool does nothing ...
there are no nuts/bolts/screws that hold the headlight switch in place
it is simply pushed in -
remove the side panel -
then push from the back and use a wide blade screwdriver to GENTLY pry it out from the front -
1 - 8 of 8 Posts
