64coupe 68coupe 82 limo
Car has done 75000 klm Messages coming up on dash " service suspension" service idle control" "speed limited to 145000 klm" "change engine oil"
Car is driving fine, have changed oil? How to get these messages to go away, or is there service req, and if so what?
Cheers Brian Brisbane Australia
maybe -
have changed oil?
either the OLM - Oil Life Monitor - was not reset at the last oil change -
OR you are again due for an oil change -
OR the engine was overheated thus triggering the change oil message -
FIX the problems triggering the warning messages -
YES - of course
and if so what?
THAT'S the million dollar question -
STEP #1 - ALWAYS - check for DTC's - Diagnostic Trouble Codes - using the on-board scanner -
if you don't know how - go here -
post any codes you have -
ALONG WITH THEIR DEFINITIONS -
include whether they are C-Current or H-History -
for code definitions - go here -
here is a how-to video -
I suspect you'll get codes pointing to failed struts and/or shocks -
these probably caused the service suspension and speed limited messages -
the codes will tell us what we need to know -
maybe -
have changed oil?
YES - of course
and if so what?
THERE ARE NO CODES ?Have scanner
with THOSE messages - there ARE going to be codes -
use the ON-BOARD scanner and check for codes -
