Very nice......I'd be nervous about trying to make something fit however........
JET
JET
Per Pete from Cadillac MotorsportsJ.E.T. said:Very nice......I'd be nervous about trying to make something fit however........
JET
1/4" should be plenty of space and I am not worrying about inspections since my cars next inspection would be in 2009. (New cars do not need to be re-inspected in NJ for 4 years.) I've done alot of reading on this subject and it looks like spacers are very common. If the shop has some cheap ones I will probably pick them up and get the STS rims on the car and I will order some custom made hub centric ones from Pete for a permanent installation.-1- said::hmm: Tom, the STS wheels look great. I agree, I would rather the wheels fit without a spacer, the same with our CTS. Per Pete from Cadillac Motorsports, if that's the case why don't they come with spacers from the factory? When I needed spacers, I found that most automotive stores don't sell them. Most people say they're against the law, I don't know. It also becomes an issue when you get your vehicle state inspection. I asked the guy who did our inspection and he said no problem. From what I've heard, hub centric spacers are the best. I'm sure you wont be able to get a 1/4" hub centric spacer made due to the spacing on the hub. That's what I was told when I had mine made. You could go with 1/4" non hub centric spacers. If you go with anything larger than 1/4", you'll have to change the lug bolts. Most wheel spacers you'll find are generic, fit many bolt patters. There are many people on ebay that will custom make spacers to your specs. That's what I'd recommend. The 18" STS wheels and the larger 245X45X18 tires look great. I've had the spacers on our CTS without any problems with vibration or tire wear. Your close to achieveing that unique look.
The new CTS 18's will be 7.5" and the tires will be 225's which will leave plenty of room. The way the 8.0" rim is designed the 225's would not look correct on these rims. Using 1/4" spacers on these STS rims I saw the tire and they put quite a bit of pressure on the rim to simulate a hard turn and the wheel does flex and it can rub against the pinch bolt. The installer had nothing to gain either way but when I asked him if it was his car would he use them his answer was "Definately Not"odysseus said:Tomm,
Are these STS wheels 51mm offset? If the new CTS wheels are still 51mm offset, you'll still have the same problem with 245's. 1/4" spacers are roughly 6.5 mm. This would make the effective offset of those wheels 44.5mm (51-6.5). The Vauss wheels have 44mm offset, and they come with 245s. The V comes with 42mm offset. My wheels have 40mm offset, which is less than half inch difference from the stock CTS.
1/4" spacers should be plenty. My biggest concern would be having at least three or four turns of thread engaging on the lugnuts after adding spacers.
A different size tire would prevent the fender from rubbing but the rim itself was too close to the control arm itself (Not just the pinch bolt). We are talking we could measure the space with cat whiskers. I can now see why its suggested that you go no more than a 40-45mm offset on an 8" rim. 51mm on an 8" rim is no good for a CTS.PAW 47 said:Tom,
Silly question why not just use 235/45/18's? They have a few brands..in that size they also have them in 235/40 as well..
I have no interest in 17's. I actually bought a set of those a few months back and I sold them to a forum member for $400. I already have a buyer for $800 for the Rims without the tires and I had no problem returning the tires. I still like the design alot and I will buy them as soon as I see a set of the CTS 18's hit the streets with the correct offsets.Tony Orlando said:How about trading me for a set of STS 17in polished wheels with 255 rear/235 front Michelin HXMXM4 tires?7000 miles on the rubber, no curb damage (or any damage) to the wheels, no vibrations in the tires. PM me if you're interested.
I agree Tomm...He's a cute kid!tomm said:After all the calculations and threads over offsets and tire sizes what it comes down to is this. The STS 8" Rims do not look good with a 225/45 size tire since the tire when installed almost looks thinner than the rim. 245/45 is definately the perfect size for this rim but there is a problem. Once installed there is around a 1mm space between the pinch bolt and the tire. So yes it fits but with 1mm or less space its not a safe install. I had trouble getting 6 sheets of paper between this space so it might even be smaller than 1mm.
I am bringing the tires to the shop tomorrow morning to have them look at it and see what we can do. When speaking with the shop they said that if I use a spacer more than 1/4" I will need new bolts installed but once I do that I would most likely have issues with the GM warranty on any of the brake components.
I definately love the look of these rims and I will do what it takes to get them on the car and I am hoping that a 1/4" spacer will do the trick. Here is a picture of the front rim installed right before I had removed it. My son wanted to be in every picture I tried to take so I gave up trying to take a picture without him.
What do you think?
