Guys,
Quick question. My uncle has a 96 sedan deVille and went into a shop that said he needed new struts. They said for this year car, the only struts that can be used are Delco which run approx $900 a pop. I highly doubt this and find the shop he went to a bunch of crooks.
Does anyone know about the 96 sedan deville and the suspension setup and if any others can be used like KGB, Konigs, etc?
Thanks so much for any help you can give me
Caddy Newbie
'98 STS (RIP @ 206,xxx miles)
You can get an idea of OEM parts prices from the guys at Brasington Cadillac - Saab in Florida. Call 352-378-5301 and have the VIN in front of you. Tell the parts counter guys you are asking for their web pricing.
If the car was built with electrically adjustable struts and that is what you want to go with, the price will be a little bit of a shock (pun intended).
You can substitute non-electric struts that are spec'd. for a similar model year car without the electric feature, but that involves fooling the ride control module into thinking there really are electric struts installed. Not difficult to do, but it is required to avoid the SERVICE RIDE CONTROL (or whatever the text is on that model) message.
94 Eldorado, and a 99 ETC
Look up companies like Arnott, Boston suspension, and Strutmasters (I know there are more, just can't think of them right now...)... They all sell passive replacements... The thing is that they usually don't supply the correct electronics to get rid of the SRC message. What they usually supply is a 12ohm power resistor, which works on the CVRSS system that was implemented in 1997, and the resistor also works on the cars that have the 4.9 engine. Since yours is a 96, the resistor wont work because the module measures the inductive frequency of the dampering valve, so you would need an inductive (electromagnetic) coil that puts out that frequency to get rid of the message.
You should remove the dampering valves from the old shocks/struts and reuse them. It's not that hard to get them off, just take a large adjustable wrench to it and it unscrews. The dampering valves are the things protruding from the side of each shock/strut.
When you get them off, make sure you weatherproof them really good before plugging them back in and tieing them off in an out of the way place. Once their in there, the RSS module will think you still have the OEM shocks/struts and it wont put the message up.
Once the dampering valves are taken off of the shocks/struts they will be leaking hydrolic fluid, be careful because it is very hard to get that smell out of fabrics (I know from experience. LOL).
Hope this helps.
Guys,
Does anyone know about the 96 seda deville and the suspension setup and if any others can be used like KGB, Konigs, etc?
Caddy Newbie
Hi Caddy Newbie;
Bad news sir,,, I own a 96 Deville Concours and just went thru what you have described,,, It’s either about 1000 for the rear and almost the same for front,,, I made the big mistake of installing a passive shock/strut system.
As soon as I saw the 150 lb each rear shocks and front struts with giant coils,and then installed best Arnot
Struts and air Armot Rear at about
500 rear and 400 front,,,, luckily my mechanic took pity on me and charged
275 labor for 3 full hours,,,,
Now my once gorgeous riding Caddy now rides like a pickup,, if you love your Cadillac ride, pay the extra 1000 $$ dollars,,, you’ll glide down Caddy Lane
The person you're quoting made ONE POST 14 years ago.
Be sure to reference the age of the thread before you respond to it.
and for future reference -
the BEST solution is to convert to the non-electronic struts and shocks -
STRUTS -
MONROE 71854 - around $65 each -
amazon.com is a good source -
SHOCKS -
MONROE 40046 - around $125 each -
YES - these are the air-assist type -
SPECIAL NOTE on the rear shocks -
DO NOT be tempted into the plain shocks or the coil-over shocks -
the car NEEDS the type with the air bladders for the ELC - Electronic Level Control - system -
and IF the compressor - or other ELC components - don't function properly -
get the MONROE AK29 - MANUAL-FILL kit - around $15 -
this allows you to inflate/deflate the air bladders manually - as needed - when the load changes -
