I remember a long thread about putting in a resistor to fool the suspension system. I’ve finally got my caddie ready to roll again and can only find one reference to a 12-ohm resistor. Does anyone know if this will work on a 96 sls suspension? All the references seem to be for an sts suspension, which I believe, uses a different strut.
Any recomendations? I have lots of pictures on what not to do and will post an update once I can fully road test it. I really just need the rear level controll to work and Im just thinking about putting in a manual fill valve. Of course Im not certain what the system will do with all 4 struts just left unplugged.
David
2005 CTS-V, 1994 Infiniti Q45
You can disable it through the OBD...... Not sure how, but I believe it was recently post here...... Goto www.caddyinfo.com and its on there.....
Discussion Starter · #4 ·
I believe the obd bypass was just for the error code; I want the rss system to think that I have active struts so the ride-leveling feature will still work. I have found several replacement struts that fit a 96 sls but the default rear ride height is 25" unless the air shocks lift it up. It looks a little funny with the front set to 27.5" and the rear at 25".
I’ve read several in depth and long threads about the cvrss bypass using a 12 ohm resistor but the thread that continued for the non sport suspension just kind of petered out. The last post I remember had someone trying 6 and 8-ohm resistors and the some sort of a loading coil. If I could get original struts back from the remanufacture I sent them to I could just cut out the old coils and measure them. My car has been down for many months working this out. I guess I should have just put in the factory struts.
David
I cant help you any more with this...... Its beyond my knowledge.......
Im sure somewhere (maybe with the help of a techII) they could program the computer to use the 25" ride height.......
Discussion Starter · #6 ·
I ended up using a set of passive AC Delco 5808 rear shocks for a deville that I got from rock auto and some 10 ohm 50 watt resisters from digikey. Ive been driving it for a couple of days now. The ride level works, it rides just fine and no codes. It was about $350 total installed.
So it does work on the sls suspension as well.
