1 - 11 of 11 Posts
CTS-V
Changed to a B&M shifter and stripped the knob. Called the dealer and they want $192 plus tax for the knob and the boot!:banghead: I don't want to permanately mount it to the shifter to fix the problem. Does anyone have a stock black shifter in good condition they are willing to sell. Thanks.
Geoff
· crushing Vs with my Wurm
2013 GT500 - 700+ HP
DD,
Did you strip the knob or the shifter handle itself? The knob can be had at GMPD, or call Van Devere Caddy in Akron and Dal will help you out. I had the Katech shifter w/stock knob and I spun the knob too tight and it stripped out the plastic sleeve inside of the knob, so I had to order a new boot/knob combo. See the faq for pn
F
04' CTS-V, 04' Escalade EXT
I don't know if this is the same issue I had with my stock knob but:
After my car was at the dealer for a re-program temp guage my shifter knob would spin in my hand. What I did was take an small nail, heat it and push it thru the plastic (back of knob on dash side). Then I grabbed a 8/32 tap and tapped threads into it. Then I used a 1/2" X 8/32 Hex Skrew to tighten it up. You could use two if you want. It tightened it up good as new, probably better.
Might save you a couple of bucks/easy fix.
I thought of doing that too. But in the end, the knob was on a Katech shifter (which was threaded) and I was changing back to the UUC (which is click-fit), So I tossed the whole shifter assy with knob and I havent looked back.
F
1 - 11 of 11 Posts
