1 - 20 of 52 Posts
2010 CTS4 Sport Wagon
So, I closed opened the driver side door with the remote (last week), got in and noticed that the passenger side exterior mirror was pushed up. Thinking someone had knocked it or whatever. I adjusted the mirror back to where it was supposed to be. Next time I went for a spin, I opened the locks with the remote and again noticed that the mirror was again askew. I adjusted it again. After adjusting, I hit the open lock button on the remote and it went up! Now i'm confused...activating the locks from the door handle had the mirror not moving as it should. Anyone with similar woes?
Oh, oh, also, the other day, I got a message that said "Driver Door Open", but it wasn't. Dunno if this is related or what? Heavy sigh...
· Super Moderator
What is your vehicle battery age and condition?
Sometimes low voltage can cause strange electrical happenings.
Reactions: B.W.Bandy
· Super Moderator
2011 SRX4 3.0 4WD, Luxury
different fobs can be programmed to adjust the seat, pedal, mirrors when you unlock, perhaps the settings got scrambled? its in your owners manual
Battery is 2018 vintage and the screen tells me that I'm anywhere between 14.0-14.4 volts while running...
Fobs have never been played with in my 6 years with the vehicle.
Could be the latch , though install has a good feel...
· Super Moderator
2023 CT5-V RWD / 2020 XT6 Sport / 2024 Lyriq AWD (reserved)
I wrote "latch" but meant door lock actuator. It's the part that receives the signal from our fobs. It also "tells" the car that the door is shut. I had one fail under warranty and the car behaved oddly until it was replaced. Years later, I had to replace the microswitches in the handle but the only symptom I recall from that part failure was that the door wouldn't unlock as reliably as it had.
Also, have you checked out this thread: Stop the (soaking carpet) Insanity Forever! - Ultraview...
Discussion Starter · #7 · (Edited by Moderator)
I said "install", but I really meant "closing has a good feel"
This past summer I had to change both front door lock actuators. If that has anything to do with it...
· Super Moderator
That is indeed interesting. Did you use OEM parts?
'14 CTS-V LongRoof; Audi RS6 Avant; '16 ATS-V Sedan gone; '10 CTS LongRoof gone
This car is the craziest car when it comes to electronics. Therefore OEM is absolutely the only way to go.
  • Helpful
Reactions: silversport
2011 CTS4 Coupe, 2014 ELR, 2018 XT5 AWD
Does your vehicle have the driver's seat memory option. If there are buttons on the door somewhere that have 1, 2 and set on them then you do. Tha system also moves the mirrors when you unlock the car. The memory might have gotten reset. Look in the owners manual to find the instructions and reset your memory after you readjust the mirror. Another cause could be a failed position sensor in the mirror. That could be sending a bad position signal to the memory module that then is moving the mirror to the wrong position.
'12 CTS Performance Sports Wagon AWD
Running voltage means nothing. Unless it drops to 12.5 after a while since these are "smart" alternators. If it drops to 12.5 then it is seeing the battery as fully charged. If it doesn't ever drop then it is a sign your battery may be old.
The issues these cars have issues happen long before you see a noticible dropoff of your battery with your car turned off. Your battery will still test good and it will still cause issues in your car. If your battery is over 3 years old and you do ANYTHING to require a jump, the chances are you will need a new battery. At 5 years old... You need a new battery...
  • Helpful
· Super Moderator
Using any non-OEM electrical part is not good on these cars unfortunately.
You should get your battery load tested. Eliminate the obvious culprit.
Discussion Starter · #15 ·
So here's what's happening now...
Checked battery voltage first thing yesterday morning and it told me 11.8 V. It's been snowy and cold so everything in the car (fans, defroster, etc.) had been running the day b4.
Re-adjusted my seat, mirrors. Saved that with the door button for fob1. Locked the doors from the interior handle hit the open button on the Fob1 and all it did was open the locks...YAY, the mirror stayed put! Then while trying the same with Fob2 I discovered that sitting for countless years on a hook, the battery was dead in it.
Lastly, I visited my garage after work yesterday and he put the code reader on it and discovered nothing was amiss. So, he reset the codes and said try that.
I don't know if that included battery load test, but since then no other irritating errors pop-up on screen.
Perhaps for valentines Day I should buy my girl another AGM battery?
She'll love you for it, lol!
  • Haha
2014 CTS4 Sport Wagon*2016 CTS V-Sport Premium
buying the correct battery would be my suggestion...our CTS' did not come with the AGM...sounds like you have your issues fixed...good luck
Bill
Discussion Starter · #18 ·
Bill
I guess depending on where you are denotes OEM equipment, but when the original battery died, an AC Delco AGM was what was in it. That day it died, I learned what an AGM battery was.
· Super Moderator
The Gen II CTS was never equipped with an AGM battery from the factory so your battery was replaced before the unit most recently.
1 - 20 of 52 Posts
