CTS Drain Tubes: The Final FRONTier!
Hi all, almost a year ago now I posted a thread about the CTS rear drain tubes:
http://www.cadillacforums.com/forum...337-stop-soaking-carpet-insanity-forever.html explaining that it's not the drain tubes at fault in our cars, but where they terminate that has caused all the grief with interior flooding, fried electrics and moldy stink. Toward the end of the post I mention how I no longer worry about the front drains because my rears were now working so efficiently. Well I should've worried, because last weekend as I prepared to change the oil and do the centre mount stop light silicone fix I noticed the passenger footwell was drenched, and I mean drenched in water. Turns out my new parking spot angles so that all the water draining through the Ultraview uses just the front passenger drain tube, and it was completely clogged.
I had to figure out how to get to where these front tubes end and fix them, so I assumed I could find them behind the front wheel well cover. I jacked up the car, removed the wheel and the cover and...nothing. I looked and felt around everywhere and couldn't find it. I put everything back together, cursing as I went, and went into the car to search and I found them. Those little SOB drain tube ends, I found them!
I recommend you do this procedure, because it's not leaves, or bits of bark and anything other than
fine grit dirt that stops up the front and rear drains. There was no reason GM chose to block off the end of these tubes that I can figure other than perhaps they thought it would prevent insects from taking up home in them? I don't know, what i do know is the design of both the front and rear drain plugs have caused many many thousands of dollars in damage, wasted labour and grief.
This fix is actually pretty simple, so let's go:
First, carefully pry up the trim piece next to the kick plate. It will likely pull away from the grommets holding it down, but that's OK, you just twist them off the metal and reattach them to the trim piece before putting it back afterward.
Pull away the carpet and check, I had about an inch of water pooled up where all the wiring and a junction box is, fantastic! That, and the underside padding of the carpet was soaked, despite the carpet itself feeling dry. I inserted a rag into the space to soak up the water about ten or fifteen times, then pressed both sides of the carpet together much like you'd push a sandwich together to squeeze the water out of the underpadding, then soaked that up with the rag I kept ringing out. Next, I removed two philips screws at the front of the underdash trim, then used a rachet and 7mm socket to remove the small bolt at the rear. I pulled it down, then pulled out the carpet and the sound insulation behind it, exposing a small access hole just big enough for a hand to get through. I felt around and located where the drain tube plugged into a panel and carefully pulled and twisted, making sure not to pull down in the tubes for fear of disconnecting it from the roof itself. Here's the result:
Here is the offending rubber drain plug. Take care to gently pull the grommet from the tubes, and again DO NOT pull down on the tube, hold it steady:
And here is the deficient design. Unlike the rear grommets which seal flat, these were given a very small cross cut which also plugs up with very little silt. I must say again that when I've done both the rear and now front drain tubes that no foreign material comes out other than fine dirt. No leaves or anything else. Good job, GM!
I removed the rubber piece from the driver's side as well. I pulled off the trim piece and pulled back the carpet and insulation. This side is very tight, and I had to contort my hand to get into the space. Wiggle the rubber part until it pulls away, then carefully bring it out through the access hole. Again, carefully pull it off the tube while ensuring you're not pulling the tube down and risking pulling it off the roof. This side was harder because it was glued better.
Finally, with both lousy rubber grommets in hand, I turned on an element on the stove, and placed a 6 inch screwdriver bit onto the element. I allowed it to get very hot, then picked it up with pliers. (please be very careful here) I inserted it into the grommet to melt away the rubber, leaving a clean open hole right through:
And that's it. Now all four of my drain tubes will never clog again. Make sure to tightly grasp the rubber grommet when feeling around putting it back in. If you drop it you're screwed and I have no idea how to get down to where it would rest if dropped. You really have to press and twist it back into place and you're working blind which is why I did not connect it to the tube first. Once it's secure then connect the tubes to the grommets, again by feeling around. You may choose to apply glue to it before connecting but I didn't. I tested how much force was required to pull it away and it's secure enough for me.
A note about the asinine front grommets, I wondered why I couldn't clean out the clogged front tube with with the derailleur cable I used last year or even weed whacker line and now I know why. The tubes turn 90 degrees before mounting to the inner fender and when the line clears the turn angle it always hits one of the rubber parts that stick out in the cross hatch. They're firm and that's where your trimmer line stops. It's nearly impossible to push hard enough to overcome them and the grommet stays clogged up. Now when I feed the cable down and through you can hear it tap the inside of the fender, instead of just stopping at the grommet.
This fix procedure may sound daunting but it's simpler than it looks!
