Sounds like the 150 shot is on the safe side. I may be looking to bump that up a tad. 200???The last time at the track we thru some huge jets at it. I will check to see what they were when I pull then out (soon).
If you're going to go over 150 I'd at least recommend going to a two-stage setup.Sounds like the 150 shot is on the safe side. I may be looking to bump that up a tad. 200???
The engine is 100% stock.
I have head studs, so I should be good.If you're going to go over 150 I'd at least recommend going to a two-stage setup.
A single-stage 200 shot on a motor with known HG sealing problems...I wouldn't be surprised if you at least pushed some water, if not popped the HG at some point.
