Rough, Unstable, or Incorrect Idle and Stalling
Inspections
Action
DEFINITION: Engine runs unevenly at idle. If severe, the engine or vehicle may shake. Engine idle speed may vary in RPM. Either condition may be severe enough to stall the engine.
Preliminary Inspections
• Refer to Important Preliminary Inspections Before Beginning in Symptoms - Engine Controls .
• Search for bulletins.
• Verify that the powertrain control module (PCM) grounds are clean, tight, and in the proper locations. Refer to Power and Grounding Component Views in Wiring Systems and Engine Controls Schematics .
• Remove and inspect the air filter element for dirt or for restrictions. Refer to Air Cleaner Element Replacement . Replace as necessary.
Fuel System
• Inspect the fuel injectors. Refer to Fuel Injector Coil Test , Fuel Injector Balance Test with Special Tool or Fuel Injector Balance Test with Tech 2 .
• Inspect for incorrect fuel pressure. Refer to Fuel System Diagnosis .
• Inspect for a restricted fuel filter. Refer to Fuel System Diagnosis .
• Inspect for a contaminated fuel condition. Refer to Alcohol/Contaminants-in-Fuel Diagnosis .
• Inspect that each fuel injector harness is connected to the correct injector/cylinder. Relocate fuel injector harnesses as necessary.
• Inspect for the following that may cause the engine to run rich:
- Notice: Refer to Heated Oxygen and Oxygen Sensor Notice in Cautions and Notices.
Water intrusion in the heated oxygen sensor (HO2S) connector
- Engine oil contaminated by fuel
- An evaporative emission (EVAP) canister purge condition
- Incorrect fuel pressure--Refer to Fuel System Diagnosis .
- A leaking fuel pressure regulator--Refer to Fuel System Diagnosis .
- Leaking fuel injectors--Refer to Fuel System Diagnosis .
- Manifold absolute pressure (MAP) sensor operation--Refer to DTC P0106 .
- Vacuum hoses that are split, kinked, or improperly connected
- An air intake duct that is collapsed or restricted
- An air filter that is dirty or restricted--Refer to Air Cleaner Element Replacement .
• Inspect for the following conditions that may cause the engine to run lean:
Water intrusion in the HO2S connector
- An exhaust leak between the HO2S and the engine--Refer to Exhaust Leakage in Engine Exhaust.
- Vacuum leaks
- Restricted fuel injectors--Refer to Fuel Injector Balance Test with Special Tool or Fuel Injector Balance Test with Tech 2 .
- MAP sensor operation--Refer to DTC P0106 .
- Fuel contamination--Refer to Alcohol/Contaminants-in-Fuel Diagnosis .
- Vacuum hoses that are split, kinked, or improperly connected--Refer to Emission Hose Routing Diagram .
Sensor/System
• Inspect the crankcase ventilation system for proper operation.
• Use a scan tool in order to monitor the knock sensor (KS) system for excessive spark retard activity.
Ignition System
• Inspect for proper ignition voltage output with the J 26792 Spark Tester . Refer to Electronic Ignition (EI) System Diagnosis for procedure.
• Remove spark plugs and check for the following:
- Wet plugs
- Cracks
- Wear
- Improper gap
- Burned electrodes
- Heavy deposits Refer to Spark Plug Replacement .
Refer to Spark Plug Inspection and Ignition System Specifications .
• Inspect the spark plug wires. Refer to Spark Plug Wire Inspection .
• Soak the secondary ignition system with water from a spray bottle. Soaking the secondary ignition system may help locate damaged or deteriorated components. Look and listen for arcing or misfiring as you apply water. Monitor the Misfire Current Counters while driving the vehicle in the conditions that the misfire occurred. If a misfiring cylinder can be located, use the DTC P0300 table for diagnosis. Refer to DTC P0300 .
• Inspect for loose ignition coil grounds. Refer to Electronic Ignition (EI) System Diagnosis .
Engine Mechanical
• Inspect engine mechanical for the following:
- Compression--Refer to Engine Compression Test in Engine Mechanical.
- Sticking or leaking valves
- Worn camshaft lobes
- Valve timing
- Bent push rods
- Worn rocker arms
- Broken valve springs
- Excessive oil in combustion chamber or leaking valve seals. Refer to Oil Consumption Diagnosis in Engine Mechanical.
• For incorrect, worn or damaged basic engine parts. Inspect the following:
- The camshaft--Refer to Crankshaft and Bearings Cleaning and Inspection in Engine Mechanical.
- The cylinder heads--Refer to Cylinder Head Cleaning and Inspection in Engine Mechanical.
- The pistons, etc.--Refer to Piston, Connecting Rod, and Bearings Cleaning and Inspection in Engine Mechanical.
• Inspect for excessive crankshaft endplay that will cause the crankshaft position (CKP) sensor reluctor wheel to move out of alignment with the CKP sensor. Refer to Crankshaft and Bearings Cleaning and Inspection in Engine Mechanical. This could result in any of the following conditions:
- A no start
- A start and stall
- Erratic performance
Refer to Symptoms - Engine Mechanical in Engine Mechanical for diagnosis procedures.
Additional Inspections
• Inspect the exhaust system for possible restrictions. Inspect for the following:
- Inspect the exhaust system for damaged or collapsed pipes.
- Inspect the mufflers for heat distress or possible internal failure.
- Inspect for possible plugged catalytic converters. Refer to Restricted Exhaust in Engine Exhaust.
• Inspect for faulty motor mounts. Refer to Engine Mount Inspection in Engine Mechanical.
• Inspect the intake manifold and the exhaust manifold passages for casting flash. Refer to Intake Manifold Cleaning and Inspection or Exhaust Manifold Cleaning and Inspection in Engine Mechanical.
